Results 1 to 15 of 21
Thread: aqua buff
09-06-2012, 02:42 PM #1
aqua buff
how many have used this aqua buff if so how does it do seems to be priced pretty good. how much would it take to do a 28 ft boat top an sides, an also i have been looking at buffers any suggestions on one i dont want to spend a fortune on one but want decent quality be able to go start to finish with out burning it up half way through. thanks in advance
79 Baja 18ss merc 2.5
94 trophy 2352 (sold)
85 checkmate enchanter merc 2.5
09-06-2012, 03:15 PM #2
Don't know about Aquabuff but I have a 7" Pittsburg wheel from Harbor Freight $40 that runs strong, I've used it for a few cars and boats.
2004 Hydra-Sports Vector 2600 - twin 225 Yamahas
09-06-2012, 04:36 PM #3
i was just looking at the mikita buffers might go ahead an get one of those they are not to bad around 200 bucks with some pads an a case
09-07-2012, 08:20 AM #4Member
- Apr 2011
- grove ok
- 83
Aqua Buff works great on gel coat cuts and cleans up great been using it for years Really brings faded Gel back to life. I use a Snapon varible speed buffer with a wool pad
09-07-2012, 08:50 AM #5
7 to 3pm 5 days a week
Custom Fiberglass and Paint
In Business since 1984
for sale
09-07-2012, 10:12 AM #6
Does it last? My deck is pretty bad, it kinda comes up when I hit it with a wheel and 3M marine compound but doesn't last long. I was going to get it painted, my painter suggested wet sand but can't do it till winter. Should I try Aquabuff first?
I need 7" velcro on buffing pads, can't seem to find them. Everywhere I look online it's always a kit that includes the wheel. I just want the pads.Last edited by at100plus; 09-07-2012 at 10:18 AM.
09-07-2012, 10:16 AM #7
Also where do you buy? Is it Aqua-Buff 2000? I see that on Ebay for $18.99 / gallon. White bucket green letters.
09-07-2012, 10:53 AM #8
I also would like to know about 7 inch pads
09-07-2012, 08:49 PM #9
Aqua-Buff 2000 Is gangster ,, We use the compand and the wax . Its the Best I have ever seen , used 3m before And its ok But Aqua-Buff I think is the best .. Lasting ? I really dont know I have a ****ty Paint job so I wax my boat 3 times a week
7inch wool Pad , Brush it on Buff off , ( will take work) And Brush the wax On and Flip you wool pad to a clean side and Buff off60 glasspar g3 115 merc (sold)
17 Action Marine 2.5 Mariner (sold)
18 Seebold Eagle 2.5 merc (sold)
23 Action Marine 3.0 merc (sold)
18 Action Marine 2.5 merc (sold)
32 scorpion twin 225
Run What Ya Brung And Hope Ya Have Enough
09-12-2012, 01:34 PM #10
I tried wetsanding a section with 3m 1000 grit wet/dry sandpaper and soapy water. It is a lot of work but my gelcoat is thick and I think if I wetsanded the whole thing, compound with 3m heavy duty marine compound, glaze and wax it would be like new. I just spoke to a friend who does body work, he says to DA wetsand with 1000 then hand wetsand with 3000. I'm going to look into this more and try to find the time to actually do it.
09-13-2012, 07:03 AM #11Member
- Apr 2011
- grove ok
- 83
I would say your way over kill with 3000 Gel is pretty tough stuff I general use 800 on a palm da then 1000 by hand maybe 1200 if a dark color Buff her up glaze and wax your good to go Your buddys recomendment would be right for a base coat clear coat finish
09-13-2012, 08:08 AM #12
I'm using the following 3M pads 05711 (compounding) and 05713 (polishing) A little pricey, but they seem to be lasting quite well. Think Mequires has a similar line.
http://www.amazon.com/3M-05711-Wool-.../dp/B000KSTFHQ (Can usually find them at NAPA too)
Pad have the loop part of the velcro, work fine on my Northern Tools polisher.
09-15-2012, 08:33 AM #13
How do you clean them?
09-15-2012, 08:36 AM #14
Did you see the 1 review on that wool pad? It wasn't good, says it made swirls and wool started flying off. My body guy recommended a foam pad instead. I was thinking 3000 is a bit much too, he works with cars though so that's probably why. I can't seem to find an online supplier for 3m wet/dry 6" DA sander discs either.
09-15-2012, 10:31 AM #15Member
- Apr 2011
- grove ok
- 83
Been doing custom Paint and Gel for over 40 years on boats didnt see review just know what has worked for me I have tried foam pads did not cut gel like the wool pad. Control your buffer speed again gel is much harder than paint you really have to work it Clean the pad with a spur have used a tip on flat head screw driver many times since spurs seem to grow legs and walk off right in middle of job. I cut my own paper and apply with adhisve I will use 3 to 4 freash pads on a boat You can wash soap and water and reuse pads I have some that are 5 or so years old
