Page 6 of 33 FirstFirst 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 ... LastLast
Results 76 to 90 of 485
  1. #76
    Jun 2004
    port st. lucie, fl
    crankcase is stuffed like the thanksgiving turkey, lol! you can never have enough power, so a lil more torque never hurts. i'm not running a bleed system, this engine was patterned after the 2.5/260/280 and they don't run a bleed system, alot of it has to do w/ where the fuel is injected, and this thing doesn't have any fuel going thru the reeds, so there shouldn't be any puddling issues w/ fuel. they typically use the bleed system to help improve the idle by getting rid of pudled fuel in the intake tract.
  2. #77
    Jun 2004
    port st. lucie, fl
    i do have it vacuum referenced, that way it does see less fuel pressure at idle
  3. #78
    Jul 2007
    Hamilton Ohio
    Quote Originally Posted by mrcrsr View Post
    i actually have the merc service manual for all the 3 litres, you can't figure out from the wiring diagram(or the troubleshooting guide) what the wires do. i pretty much need someone who knows or owns one of them to take a multimeter and check it. worse case i'll try it- if it doesn't work i'll have to change the wiring.
    Charlie,
    I've got a 1995 wiring diag. and it's crystal clear and easy to read right back to the ECU's
    Gary
    Growing old is inevitable, growing up is optional.......
  4. #79
    Jun 2004
    port st. lucie, fl
    the problem gary is the early engines only used 5 v reference supply to the tps only- it doesn't daisy chain around the engine like the newer 3 litres, so you basically see both wires go from the ecu to the tps only, so you can't disttinguish what wire does what
  5. #80
    Boca Raton, FLORIDA
    Charlie,
    What makes the difference between the old and new? I am assuming the old style ECU? Not sure what year my motor is as it is made up of several motors, but does have the old style ECU's if that helps.
  6. #81
    Jul 2007
    Hamilton Ohio
    Got'cha.........
    Gary
  7. #82
    i was able to reuse the msd wires i had made for the other 3 litre. does anyone know the tps wiring on the older 3 litres? the colors on the tps are black(ground), blue/red and blue/yellow- trying to figure out which wire is the 5v input and which is signal out, i'm thinking it is the blue/red is the 5v feed. thats the way i wired it unless someone knows..
    almost 100% certain the blue yellow is reference and blue red is 5v
  8. #83
    Boca Raton, FLORIDA
    Checked mine last night, and the blue/yellow had 4.8v with the key on, harness side, TPS unplugged, blue/red nada.
  9. #84
    Jun 2004
    port st. lucie, fl
    thanks rick! i'll have to change the wiring. as for your question, the newer style stuff uses a single motorola computer, as compared to the 2 merc computers on your engine, more or less newer technology. pulled the old powerhead last nite and installed the new one, had to change fuel lines and rerig a couple of things, i still have to do the starter wiring, fix the tps wiring and configure the timing before lite off!
  10. #85
    Boca Raton, FLORIDA
    Cool,
    That is what I figured with the ecu's
  11. #86
    May 2008
    Fleming Island Florida
    Nasa has nothing over you guys , this is way to cool ! great work charlie / and chaz you got another notch on your belt !
    21 Skater 300 x
  12. #87
    Apr 2006
    Viera (Melbourne), FL.
    The old ECU's (one for fuel and one for ignition) were 16 bit processors. The new style (and the Wolf) are 32 Bit. It's an exponential increase in processing ability. Going from 16 to 32 only sounds like double but it's really able to process 16 times more info.
    I love this stuff. Charlie, you need to post pics of it on the mid.
  13. #88
    Boca Raton, FLORIDA
    Quote Originally Posted by Stitch King View Post
    The only info I am processing while the boat is out is how many drinks are left in my cooler, I like 32 better, but 16 will do
  14. #89
    Jul 2005
    Quote Originally Posted by rchevelle71 View Post
    And it definatly gets extra-mental after you've drunk 32 beers
  15. #90
    Boca Raton, FLORIDA
    Quote Originally Posted by MaDneSS View Post
    Of course most of them are for the crew
