Page 4 of 33 FirstFirst 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 ... LastLast
Results 46 to 60 of 485
  1. #46
    Jun 2004
    port st. lucie, fl
    had to put a slot in the butterfly throttle shaft for the tps coupling, ended up using an older style 3 litre tps, i have a stockpile of them
  2. #47
    Jun 2004
    port st. lucie, fl
    i didn't like the internal passage size of the 300 promax fuel rail, it was smaller then 1/4", so i bored it out to 5/16", i also milled off the return passage in the rail to get more clearance for the throttle linkage, and bushed the aluminum throttle connector end.
  3. #48
    Lookin good Charlie !! Ready in 2 weeks or what ??
  4. #49
    Jul 2007
    Hamilton Ohio
    Now Gary, you should know I have three roto-tables. One that takes two people to lift, LOL One that sines 90* and another thats just user friendly... and angle brackets to stand each one on end ... even a 90* spindle drive to really make things complicated ...
    Chaz,
    Always like to hear what cha got to work with...........TOOLS, can't get enough of them to play with..........LOL !!!!!!
    Charlie,
    Look'n real good my man, won't be long till it see's "Fire in The Hole" and starts to breath. Great work !!!!!!
    Gary
    Growing old is inevitable, growing up is optional.......
  5. #50
    Nice
  6. #51
    long island
    Sweet!!
    Quote Originally Posted by mrcrsr View Post
  7. #52
    Jul 2012
    Chicago
    Interesting work gentlemen!
  8. #53
    Jun 2004
    port st. lucie, fl
    thanks guys! tom, i'll probably take captn steve's trick if this isn't done, it still has to be tuned, but i have to pull the heads on steve's engine due to some milling errors by the person i purchased 2 sets of heads from, the heads on my old motor were leaking in 4 and 6, and were not milled straight- hence the o ring groove depths have a .010 variance side to side, oh well. ronnie, i have 2 map sensors to choose from, wondering which would be more sensitive- the older 3 litre style,denso 825762. the other sensor is gm based, used on optimax and 300x and many gm vehicles, pn 16232443, or 6232(numbers on sensor)has a square trademark/manufacturer symbol on it, looks like a box and may say ce in it
  9. #54
    Jun 2004
    port st. lucie, fl
    late 3 litre/opti/gm map sensor
  10. #55
    Jun 2004
    port st. lucie, fl
    earlier 3 litre sensor
  11. #56
    Jul 2007
    Industry, PA
    Looks good Charlie! Can't wait to hear how it runs.
    85 Checkmate Starflite
    MAD/Wolf 225 EFI
  12. #57
    Jan 2003
    aalsmeer
    the beste sofar if i can find some original data sheets iw ill post them !
  13. #58
    Quote Originally Posted by Liberator*21 View Post
    Chaz,
    I feel lucky to be part of a little group of guys who work within the automotive rebuilding industry, or part of that little model rocket club we have just up the street at the cape .... . Least I forget, the one who gets paid to throw a chicken or a hand full of 1/4 x 28 nuts in a perfectly good running turbo fan and then take a month to analize what happened to the blades ... now thats a job with a lot of "stress" ....
    Cuz no one man has everything under one roof ...
  14. #59
    Jul 2007
    Hamilton Ohio
    LMAO......seems we have something in common...Jets. I'm a retired Engineer of way to many years at General Electric Aviation, Military & Commerical Jet Engine Division, and I've been in the test cell and have seen those tests in person, destructive as hell, but WAY, WAY COOL to watch........
    Gary
  15. #60
    Jun 2004
    port st. lucie, fl
    gary, years ago i watched an lm2500 come apart, it wasn't pretty!! i think it was something like 2.5 million in damage if i remember correctly, wiped out the power turbine as well. hoping to put the powerhead on tomorrow nite. i'm thinking i'm going to bring the fuel pres from 45 to 55 psi and try to fire it once i calibrate the ignition timing and see what it does, i wonder how far off the fuel curve will be, i'm thinking the increase in fuel pressure will offset the differnce in moving the injectors into the crankcase, as they will now be seeing crankcase pressure, but also this engine should make alot more power then the old one, so i can see the demand for fuel increasing.
