Results 481 to 485 of 485
07-16-2017, 03:09 PM #481
No, I control ignition and timing with the wolf, so if the idle falls below 600 I add timing, if it goes above 750 I take timing away. When I first set it up I had too much of a difference between hi and lo timing and the idle rpm surged up and down like a blower motor
07-16-2017, 10:13 PM #482Junior Member
- Jun 2017
- Canada
- 14
07-24-2017, 02:43 PM #483Junior Member
- Jun 2017
- Canada
- 14
Do you tell me what kind of map sensor was best with the number for your engine
08-15-2017, 05:17 PM #484
I used the internal map sensor with blending
08-16-2017, 03:04 PM #485Junior Member
- Jun 2017
- Canada
- 14
The engine works amazingly but I have a problem with the set up prop of the boat so that the rpm and turk are strong and you need to modify the prop
