Page 28 of 33 FirstFirst ... 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 LastLast
Results 406 to 420 of 485
  1. #406
    Jun 2004
    port st. lucie, fl
    I'm afraid to give the computer complete control, lol
  2. #407
    Jan 2003
    aalsmeer
    You can probably set the range (rpm band) in wich to run closed loop say 2000 to 4000 rpm everything above that i would do by hand to
    And midrange is most time consuming anyway
  3. #408
    Jul 2007
    Hamilton Ohio
    Quote Originally Posted by mrcrsr View Post
    LMAO.....couldn't agree more, i.e. Rise of The Machines (Terminator) is what happens when you relinquish total control...
    Gary
    Growing old is inevitable, growing up is optional.......
  4. #409
    Quote Originally Posted by Liberator*21 View Post
    Ya they decide to put windows in blocks.lol
  5. #410
    Mar 2002
    N.E. Ohio
    Camaro?
    Mirage Jaguar RiverRacer
    Polaris PRO785
    Bennington 255LCC
    Scream & Fly Flying Machine of the Month:
    September 2005
    http://www.screamandfly.com/showthre...ild&highlight=
  6. #411
    Jul 2007
    Hamilton Ohio
    Quote Originally Posted by MODVP22 View Post
    Camaro?
    Oh yeah, 10.5 @ 128, it's a bad azz street car.
    Gary
  7. #412
    Jun 2004
    port st. lucie, fl
    the camaro is stone age, and is blow thru carbureted, the only computer it has is a microsquirt running the 4l80e transmission. the boat has the capability to run a wideband, already installed the bung for it. here's a pic of the camaro engine bay, i think one of my future projects is to put a turbo on the skater engine.....
  8. #413
    Jun 2010
    UK
    Personally dont like closed loop auto mapping... Good idea in principle, but doesn't work so great in practice unless under controlled driving conditions...
    Interesting reading this thread however. As regards to extra fuel, any chance of getting an exhaust gas analyser (may not be practical at all) and seeing what kind of unburnt hydrocarbons you have before and after to see how efficient combustion is?
  9. #414
    Closed loop works fine when you have things totally dialed in. But that takes a lot of work.
  10. #415
    Jan 2003
    aalsmeer
    Quote Originally Posted by Dave Strong View Post
    took me about 2 minutes the change the necessary settings ( AFR map range, minimum engine temp closed loop to high) that,s all
    a shame i had issues with my dyno supply pump so i could not get it
    to the full throttle high rpm ranges
    plz tell what system where you running on what engine
    and what settings did you have to change?
  11. #416
    Jun 2010
    UK
    I will use closed loop for example part throttle close look fuelling for efficiency, but never use it to create a fuel map.
    Gotta say though, that video above is interesting Going to fit MS2 on my V6 at some point
  12. #417
    Jan 2003
    aalsmeer
    Quote Originally Posted by madgadget View Post
    go for the MS3 and use capacitive discharge ignition
    and the other extra features
    well worth the extra money
    <iframe src="//www.youtube.com/embed/46q35k1UNMM" allowfullscreen="" frameborder="0" height="720" width="960"></iframe>
  13. #418
    Jun 2004
    port st. lucie, fl
    i figured i would just use the wideband for a tuning reference, i don't really trust the computer enough to let it auto tune. i'll hook up the wideband with the engine in its current configuration to get an idea of where its at . i've got a couple more engines to rebuild for customers and then i'll revisit the mad efi intake.
  14. #419
    Jun 2004
    port st. lucie, fl
    ronnie(or anyone else) the 2.5 litre cd ignition with switchboxes, i know it is possible to electronically retard timing by the use of the bias wire between the 2 switchboxes, how would you use a computer(like the wolf) to do it. gonna do another wolf project down the road.
  15. #420
    Jan 2003
    aalsmeer
    hi charly i don,t use the original switch boxes
    i started out with that idea but dropped it because i could not get it to work with the 5 volt output of the MS3X card
    http://www.msextra.com/forums/viewto...?f=125&t=52253
    i build my own with the help of thierry of the http://www.transmic.net/ site
    the key is that the ecu should be able to do a coil dwell signal in % of the crankshaft rotation ( i use 90% )
    meaning the thyristor gate is kept low during 90% of the crank rotation in this time it,s charging the capacitor through the stator ignition coils
    when the signal goes high the thyristor discharges the capacitor and the charge is released to the ignition coil
    i have been looking in the wolf software but i don,t think you can do that with the wolf ecu (but you can ask them)
    you will have to go with and after-market unit of
    http://www.mwignitions.com/pg_data_sheets.php
    or maybe vipec
    aem seems to have stopped making one ( can,t find it anymore )
    i am working on a DC version that should work as a drop in replacement based on the sport-devices design
    http://www.sportdevices.com/ignition/inverter.htm
    if it works you could use it with the normal coil dwell signal
    but this is proving challenging to say the least
    Attached Thumbnails Attached Thumbnails 20140518_105638small.jpg   20140222_154244small.jpg
