Results 376 to 390 of 485
03-31-2014, 08:25 PM #376
I have used over 100 wisecos last year with no issues.
Quote Dave Bush
Top guided, side pinned, 1 ring, 2 rings are all areas we have tested. Currently we are sticking with Wiseco’s side pin, as it has proven perfect as they claim. We lose ring seal and have more significant leak down when top pinned.
04-01-2014, 07:47 AM #377
The people who "Bring good things to light" have gotten rich ( I'm also a stock holder) by protecting the wire filament of an incandescent bulb in an area (mostly) void of air molecules.
However, the principle of vacuum does not really apply to the intake stroke of either a 2 or 4 cycle engine beyond idle. If it did , the intake charge would go over 100% volumetric efficiency.
Every normally aspirated configuration we deal with, only uses atmospheric pressure to fill voids until an equilibrium is met. Yes it's true that you can use the "pressure" of a moving column to continue filling a void, but that's only good for a few % at best.
Now there are those who build additional manifold "pressure" above atmosphere thru artificial means , blowers, turbo's etc .. but that is another non vacuum related topic ..
04-01-2014, 10:46 AM #378
you can actually have pressure filling without mechanical add ons above atmosferic pressure
with the principle of helmholtz
http://www.chrysler300club.com/uniq/.../ramtheory.htm
http://en.wikipedia.org/wiki/Velocity_stack
the brucato unit can do this
although very curious how adjustable the power curve is with the stacks
04-01-2014, 05:29 PM #379
04-01-2014, 06:10 PM #380
How about why the locating pins came loose? The intake manifold does no good if the engine spews parts everywhere.i do believe velocity takes over. But, if all intake events were recorded in psia there would definitely be a difference between either side.
04-01-2014, 06:18 PM #381
04-01-2014, 06:36 PM #382
Working on a 3 liter for a buddy, due to sizing issues I'm going to use a set of WSM's.
04-01-2014, 06:48 PM #3831980 Cougar 19 tunnel,90 2.4L Bridgeport EFI in middle of restoration.
04-01-2014, 07:19 PM #384
No, first time. Used them in tons of jet ski's and snow mobiles with no issues what so ever.
04-01-2014, 07:29 PM #3851980 Cougar 19 tunnel,90 2.4L Bridgeport EFI in middle of restoration.
04-01-2014, 10:23 PM #386
04-01-2014, 10:42 PM #387
I like Wiseco's never had a problem I didn't create.
04-02-2014, 12:00 AM #388
So if the pins stayed in place for 249 hours , then you change the intake and it detonates one piston to slag and rattles the pins loose in the other five .. it's pretty easy to see what the root of the problem is. Another sure way to tell it was detonation is that the pins will be stuck in their bores.
I spoke about it on the other thread, you even tended to agree. That being that the throttle blade area is grossly exaggerated for the application.
Gary said the math show's the blade area to be more than twice that of the stock system .. If that's the case, then doesn't it stand to reason that at half throttle it is moving as much air volume as the standard system... ? Then wouldn't it also make sense that at that point, it requires the same amount of fuel as it did at WOT .. ? Of course it does ..
Now from that point on, if the MAD deal has the ability to straighten the air in larger doses, and the engine has the ability to make use of that air, then a curve adding fuel will also produce more power.
But if the motor has no use for the available air from half throttle on, then force feeding additional fuel will only make for a blubbery second half ..
Cyl heads are tested at 28" of OMC .. err ... Mercury .. thats so small changes can be recorded. Any .. cyl head or carb man will tell you the 99% of what's out there , be it 2 pokes or 4 , run at an average 1.5" of depression .. if it were not the case, carbs wouldn't need to operate within the confines of Bernoulli's principle.
Some early weirdness ...
04-02-2014, 06:21 AM #389
charly, as far as the mixture, here's one for you. at 3k rpm, fueling requirements went up about 13%.i don't look at things from a throttle opening perspective but more of tps over rpm. my engine is crankcase injected, so i'd like to think that takes out the variable for disrupted airflow as i'm injecting after the reeds. so that only leaves one possibility, that the intake truly is packing more air into the crankcase. what doesn't make sense to me is at steady state 3 k rpm, with all other variables equal(same prop,boat,load,etc) why does it require more fuel to do the same job? as far as the engine coming apart, lets just say a friend who was running the boat for me made a mistake. i was running the laptop in the passenger seat, he was driving the boat. we did one plug reading at 3k rpm, everything fine. my fuel rail and lines hold pressure for a lil while after shutting the fuel pumps down. anyway, boat is in gear, he hits the key and immediately planes, motor falls on its face, as its spinning down i heard it squeak a couple of times. boat settles back in water, he figures out he left the fuel pump off, kicks it back on, fires the engine, planes off and motor seizes. it didn't do alot of damage other then scuffing the piston and bore had scratches in it. no evidence of detonation (no speckling on plugs, etc) so not sure why you are saying detonation as i don't believe that is the culprit.
04-03-2014, 06:10 PM #390
I think it would be easier over Gatoraid next time you stop by .. LOL
But here goes ..
You could be idling along and whack it , the motor would be at 2000 rpm and WOT on the TPS .
Just as you could be cruising at 6000 and push the throttle the last little bit to WOT .
Each situation would require a different curve. So it's a good thing you do that.
It's date night, and I don't wanna keep the Mrs. waiting ...
I'll be back ...
