Results 286 to 300 of 485
01-15-2013, 08:08 AM #286
i'm waiting on the trim indicator for the 15" midsection from stainless marine, would take too much work to modify the 20" one. talk about assembly problems, you'd think mercury could remember to install all the parts in a 2600$ gear housing, it comes w/ a new zinc installed along w/ the alignment dowel pins on the top, and even a tag to ensure you fill a bare housing w/ gear oil, but yet they leave out one of the most important parts, the dowel pin the shift bellcrank sits on. i called merc customer service, instead of apologizing or anything else they say send it back, after i waited 2 months for it and paid another 140$ in expedited shipping to get it, gotta love mercury sometimes
01-15-2013, 08:10 AM #287
it was an oddball dowel pin that tapers down on the bottom, so i couldn't substitute a normal dowel pin, and you cannot get inside the housing w/ a pair of visegrips to pull it, the solution-cut up a complete fleetmaster i had here that got water in it
01-15-2013, 05:03 PM #288
o man....nuts
TRANSPORT SERVICE...UP TO 36 FEET....YOUR TRAILER OR MINE... FULLY INSURED...............
DOT & CDL COMPLIANT $500,000.00 CARGO & 1 MILLION LIABILITY.
LIVE LIFE ON THE EDGE, LESS CROWED BETTER VIEW
01-16-2013, 07:40 AM #289
it gets better, ups shows up w/ the trim indicator and it is for a 20" integral trim engine, some things are just not meant to be ,lol! this is after i had a discussion w/ stainless marine to see if they made the indicator to mount on the stbd side instead of the port side for a 15" mid, amazing people are so clueless
01-16-2013, 09:45 AM #290
01-16-2013, 05:38 PM #291TRANSPORT SERVICE...UP TO 36 FEET....YOUR TRAILER OR MINE... FULLY INSURED...............
01-17-2013, 06:59 AM #292
exactly frank, just a matter of getting to the point of being able to use them! ran it yesterday without a trim indicator and all seems good. i need to make some kind of shield for the bottom of the stainless marine jackplate, w/ the jackplate fully down it sends water shooting up the inside of the jackplate and showers the bottom of the cowling. its funny because the lower edge of the jackplate that slides up and down is 1/8" above the bottom of the hull but also is back 7", so its scooping water. if you bump the jackplate up once it goes away.
01-17-2013, 05:27 PM #293TRANSPORT SERVICE...UP TO 36 FEET....YOUR TRAILER OR MINE... FULLY INSURED...............
01-18-2013, 05:10 AM #294
Charlie, here's one of many that I've built, might just give you some ideas.........
http://www.screamandfly.com/showthre...ght=Skid+plate
01-18-2013, 06:50 AM #295
thats cool gary! i built one yesterday out of a piece of aluminum, it was a pita because the outer part that the engine bolts to and slides up/down potrudes below the stationary part, so i used 3/8" aluminum shims in the front, drilled and tapped the jackplate for 2 10/24 bolts, and made a l bracket in the aft part to support the plate, it goes from the bottom ram mount bolt to the plate w/ the bracket made of sst. i'll get some pics up
01-18-2013, 11:37 AM #296
01-21-2013, 07:59 AM #297
i'll have to get some pics up of the plate. ran the boat this weeknd and ended up putting 150 miles on it without any hiccups. it didn't gain any speed at all from the 15" mid, i figured i'd gain something getting the cowling out of the wind but no such luck. i guess it looks cool though, lol! haven't had it offshore yet to see if there was any improvement in handling. my next thing i need to do outside of the intake redesign is getting the thru hull pickup installed, the boat has the flange installed on the stbd side inside the hull w/ the hose coming off of it going to a thru bulkheah connector at the transom but there is no pickup installed, so i need to figure that out
01-22-2013, 09:31 AM #298
Ya`ll are amazing. I`ve been keeping up with this project and it has helped me with my own 3.0L deel.
DB
01-22-2013, 09:35 AM #299
Must be nice to be able to do some boating....... It was 6* this morning with an expected high of 14*! Our river temp is around 38*. Looking good Charlie!
85 Checkmate Starflite
MAD/Wolf 225 EFI
01-25-2013, 07:41 AM #300
a lil chilly here this am dave, 61 degrees i'm gonna try the 32p drag4 this sunday, see how that does. i need to fab up a thru hull pickup next.
