Page 10 of 33 FirstFirst 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 LastLast
Results 136 to 150 of 485
  1. #136
    Jun 2004
    port st. lucie, fl
    sounds good gary, hopefully gonna run it on the dyno tonite, waiting on an adapter for the dyno, should be here today
  2. #137
    Jul 2007
    Hamilton Ohio
    Good luck Charlie, hope everything goes your way.......
    Did you every hear back from Ricky @ Pro Marine on the coil refund ????
    Gary
    Growing old is inevitable, growing up is optional.......
  3. #138
    Jun 2004
    port st. lucie, fl
    they take the money quickly but refund slowly, lol! got the ra # on monday and sent back, usually its a couple of days
  4. #139
    Jul 2007
    Hamilton Ohio
    Quote Originally Posted by mrcrsr View Post
    Ain't that the truth Charlie, pretty much everywhere these days.........to those business's it's free money to make interest on.
    Gary
  5. #140
    Apr 2006
    Viera (Melbourne), FL.
    gary, do you think there is room in there to go to 12 mm? they make a 45 deg adapter that is 12 mm on one side, 18 mm on the other to accomodate the o2 sensor
    Charlie,
    I'm guessing the 45* adapter would not allow the O2 tip to be in the exhaust stream. I think you would want the tip in the stream even if it's shrouded to reduce the possibility of contamination.
    You might need something custom. I think I remember seeing a lathe in someones garage when I was down in Ohio... Last I heard he was retired and bored.
    Ken
  6. #141
    Jul 2007
    Hamilton Ohio
    Quote Originally Posted by Stitch King View Post
    Charlie,
    Ken
    Thanks Ken.....Damn..............."I'm BUSTED".........
    Gary
  7. #142
    Jul 2005
    How about straight in the side of the tuner?
  8. #143
    Jun 2004
    port st. lucie, fl
    thats what i'm thinking. gary, if i get the measurements of the tip of the o2 sensor could you make an adapter that would go in the side of the adapter plate? apparently the threads on the sensor are 18mm, not sure of the diameter of the tip of the sensor, which would dictate what the male diameter would be. threw her up on the dyno last nite, that thing screams! a couple of times it flashed thru the limiter up to 7400 rpm, pretty wild hearing a 3 litre up that high. peak torque seems to be around 4-4500 rpm. his dyno doesn't give hp measurements, just hyd pressure, but was great for loading the engine for building the fuel map. now i just need to get time to go run it.
  9. #144
    Apr 2006
    Charlie and Gary,
    I found an old Denso O2 Sensor from when I did my Chevy LS swap in my Jeep.
    Its tip diameter is 12 mm and the projection from the end of the threads is 21.75 mm.
    The threads are 18 x 1.50. At the base there is a 2.0mm sealing crush washer and the threads above the crush washer are 7.0mm long.
    You probably would want to send a sensor to your machinist just to make sure everything fits.
    Ken
  10. #145
    Jul 2007
    Hamilton Ohio
    Charlie and Gary,
    Ken
    Metric sucks !!!!!!!!!!!!!
    12 mm=.472
    21.75 mm= .856
    2.0 mm=.078
    18 mm x 1.5 tap is something I don't happen to have...........
    Gary
  11. #146
    Apr 2006
    Charlie,
    Looks like you'll need to send a tap to your machinist too.
  12. #147
    Apr 2006
    Quote Originally Posted by Liberator*21 View Post
    Yea it's a PIA. I'm just old enough that when I first started in my career all of the drawings were in done in inches. Then I had to make the switch to the metric system yet some of the old drawings still pop up and I have to take the time to convert back and forth. Like I said it's a PIA.
  13. #148
    12 mm=.472
    21.75 mm= .856
    2.0 mm=.078
    I have an 18mmx1.5 tap they have used it in the automotive world since the early 80's. But sort of a big hole to to put in an outboard exhaust adapter. They are using O2 sensors in the newer snowmobiles and from what I remember they seemed to be a smaller hole size.
  14. #149
    Jul 2007
    Hamilton Ohio
    Yeah, 18 mm is a big hole. Thanks Dave might be worth looking into...........
    Gary
  15. #150
    Apr 2006
    There is a smaller one that uses a 12mm thread but it's a narrow band sensor opposed to the wide band.
