Results 1 to 3 of 3
Thread: 1988 mercury 200 hp
08-19-2012, 03:28 PM #1
1988 mercury 200 hp
Whats up guys I have a 1988 mercury 200 that i whant to know what is the normal runing temperature . The reason i ask is cause at idle it sits around 130 degrees but when get on plain it shoots up to around 170 i back off on it and it drops to around 150. It never stops pomping when you look at the peehole. Just wana have a clear idea of whats going on. BTW has new pump i took the thermostat off to see if they were the reason but still doing the same. Thats why i want to know what is the normal temp before i start chaging parts or do something stupid. Thanks in advance for any help or advice you guys can give me.
08-19-2012, 03:41 PM #2
those numbers don't sound to bad but you need the thermo's in, or some type of restrictions in the housings to keep the block filled with water.
I think one buzzer sender goes off at 180 degrees?...and the other sender length goes off at over 200 degrees?.....Not sure which motors used which senders.JOHN MASON
'83/VECTOR/MERC 200-- SOLD
'98 Quartershot T-3/ MERC 200
"If your not living on the edge, your taking up to much space"
08-19-2012, 04:02 PM #3
Cool i just wanted to make sure so before i start to go crazy hahaha. Am gona put the stats back in and gona conect the water pres gage to keep it safe thanks.
