Results 1 to 3 of 3
    May 2006
    qold coast/brisbane, in Qld, Australia
    drystacking my 250ho
    what is involved to make my etec sandwich plate work on my 12inch omc mid? i removed my powerhead over the weekend on my 20inch and been thinking about putting my ho powerhead on top and l2gearbox on bottom. can i remove all the can or baffel with out affecting the running of the e-tec or what can be cut to the shortest to work? its set up on a australian 21foot light weight ski boat.. it is also a standard omc midsection cut down to 12inch with offshore exhaust and single ram
    Bristol, WI
    The adapter plate bolt pattern is the same.....the Etec's like back pressure, as others have found.....
    Larry Gempp Jr.
    Lots of past boats - Currently rocking a 21 Liberator
    2004 HydroStream Venom - 3.4 Etec - August, 2011 S&F Boat of the Month
    May 2006
    tuner?
    Quote Originally Posted by Speed Jr. View Post
    so in saying that... leave the tuner as long as possible and the inner baffle or dont bother doing the mod as powerhead failer will occur. would it be a more leaning out issue?
