Results 1 to 6 of 6
Thread: Poor running 1989 200 XRi
07-05-2012, 11:17 PM #1New Member
- Jul 2012
- Bellevue, MI
The motor starts good, but when I give it gas to plane out it seems like it is low on torque. Once I'm on plane it takes a lot longer to reach even 5000 rpm. More often than not 5000 rpm is all it will twist. Every now and then once I hit 5000 and stay into it, it will work its way up to 6000 to 6200 rpm. This motor is on a 1977 Python 18' hull. It does have a CLE gear case, I'm running a 24 pitch chopper 3 blade prop. HELP!!!
07-06-2012, 06:48 AM #2
The first thing I would do is check compression to verify you have 6 good holes.
RockTeam Junk
07-06-2012, 08:22 AM #3New Member
- Jul 2012
- Bellevue, MI
All right, that will have to wait until Monday when I get back to work.
Thanks.
07-07-2012, 10:28 AM #4
I would also check the vac fuel pump on the side of block, my friends efi had similiar problems, $20.00 rebuild kit and ran fine.
1990 Viper 140 crossflow
2011 Sea Hunt 232 Ultra
1995 Laser 380
1984 Reaction 19 project.........
07-09-2012, 10:53 PM #5New Member
- Jul 2012
- Bellevue, MI
Well, I checked compression and found 2 low holes. Hoping stuck rings but I never get that lucky! Thanks for the input.
07-10-2012, 07:18 AM #6
If you're gonna hope may as well hope for a blown head gasket. That would be real lucky.
RockTeam Junk
