Page 4 of 9 FirstFirst 1 2 3 4 5 6 7 8 9 LastLast
Results 46 to 60 of 125
  1. #46
    Oct 2005
    Akron, OH
    Shaun (2.5_Stoker), I'll definitely let you know how this new foot throttle works. I've got one of the initial prototypes reserved and going into my boat when available.
    As former GE guy, everything Gary touches is well-thought out and highly engineered. This new pedal will be no different.
  2. #47
    Shreveport, La.
    Quote Originally Posted by Liberator*21 View Post
    As an added note to this thread, depending on timing and interest, thinking of offering a retrofit kit for existing owners of the "N-Control" foot throttles that would like to upgrade to a new captive roller track, rollers and linkage/roller arm. Would make for a great winter project, you'd send me your existing foot throttle and I'll upgrade it and return ship to you via priority mail, should be able to handle it all once received within a week. Let me know if there's any interest in this and I'll see if it's worth the time to pursue.
    Thx.............
    Absolutly! I would do this in a heartbeat because of the fact that i paid retail for my In-Control peddal and really don`t want to simply throw it away. Your repair/modification idea is spot on.
    DB
  3. #48
    Jul 2007
    Hamilton Ohio
    DB,
    Since you were the one to post the question of repairing an existing N-CONTROL foot throttle, I'd like to offer you a "FREE" roller track repair of your current unit. All I ask is that you pay for shipping to and from, then honestly comment on it once it's returned to you and you've had a chance to use it again. If your interested PM me and we'll set something up.
    Thx
    Gary
    Growing old is inevitable, growing up is optional.......
  4. #49
    Jul 2007
    Hamilton Ohio
    Added note:
    In reply to someone who ask if the floor mount hole pattern is or will be the same as a "Hot Foot Pedal", originally I said yes, but after a long and hard look at the design it I can't really justify the extra material or weight to do so, so I'm sorry to say no it won't be.
    There is no need to have such a large base plate (floor mount) with my unit. The Hot Foot type floor pedals requires it due to the very large return spring thereby naturally forcing you to exert more forward foot pressure. This pressure is spread out over a larger floor contact area, i.e., larger floor base plate/hole pattern.
    Gary
  5. #50
    Shreveport, La.
    Thanks Gary. You have a pm.
    DB
  6. #51
    Jul 2007
    Hamilton Ohio
    Quote Originally Posted by Da Bull View Post
    DB
    DB,
    Got it, ship to address sent, thanks for allowing me the opportunity to repair your throttle........
    Gary
  7. #52
    Jul 2007
    Hamilton Ohio
    First look at the N-CONTROL foot throttle rebuild. It's smooth, strong, will never jump out of its track, rollers are 100% larger, roller axle is 304 Stainless Steel. If interested in getting yours rebuilt, contact me.
    Gary
  8. #53
    Jul 2013
    Looks nice. Is that track a machined from solid billet?
  9. #54
    Jul 2007
    Hamilton Ohio
    Thx, track is extruded material to my specifications.
    Gary
  10. #55
    Jul 2013
    Extruded material made to your specs, I guess you're planning on making and modding a lot of these!
    Is that a stainless cap on top of the extrusion?
  11. #56
    Jul 2007
    Hamilton Ohio
    Quote Originally Posted by Onetime View Post
    Yeah, having material extruded to custom spec's ain't cheap....., but your correct in your assumption, I do plan on making/rebuilding quite a few as the price and quality are far superior to the other guy's product and I guarantee it for life, you break it, send it back and I'll send you a new one, nobody can match that claim. At the top is an aluminum cable mounting block as this control is top loaded. The only Stainless steel used is the hardware, i.e. screws, washers, nuts and hinge. All screws are socket head, not screwdriver types, makes for a much more impressive look and easier to tighten hardware. The prototype design is currently being tested and abused as we speak in 3 boats, the actual design (may) change a little but not by much if any depending on testing results, here's a sneak pic of the actual prototype that's under going testing:
    Gary
  12. #57
    Jul 2013
    Looks very nice. Best of luck with it. How much do expect them to sell for?
  13. #58
    Jul 2007
    Hamilton Ohio
    Under $300 + the trip.
    Gary
  14. #59
    Richland, WA along the Columbia River
    Hey, I like the fix.
    I have a twin set up and one side worked well and the other would bind. So went the home engineering route.
    I will show you how I modified mine. Works great, I can run the throttle with one finger.
    I like the footpedal, but hated that whole cable pulley set up. I went old school. I took the peddle hinge assembly apart and inserted torsion springs at that the peddle. I cut a lever that gave me a better pull, while doing away with the pulley setup. I replaced the nylon roller with ABEC 11 roller blade bearings, they fit perfectly and are rebuild-able. I wish the original setup worked better.
    I also through away the spring setup at the motor. I went old school back there as well. I installed a carburetor return spring back at the motor. There are a lot if places to mount from.
    I also replaced the stock cable with a 33C. I love the whole set up.
    I have plenty of adjustment with stops as well. I have been running it for almost two years and no issues at all.
    Attached Thumbnails Attached Thumbnails DSC_6767.jpg   DSC_6763.jpg   DSC_6742.jpg   DSC_6731.jpg   DSC_6736.jpg
  15. #60
    Jul 2007
    Hamilton Ohio
    That's a very impressive change out, looks great. Thanks for share'n. I had thought about the torsion spring too but decided to keep it simple as the torsion spring adds a little more complexity to the pedal and hinge, I'm try'n to keep cost down, but quality & reliability high and still be able to guarantee it for life.
    Gary
