Results 1 to 15 of 17
    Oct 2009
    Townville, Pa.
    1974 BAJA V-1500 restoration.
ID:	258150Click image for larger version.
ID:	258151Click image for larger version.
ID:	258152Click image for larger version.
ID:	258153Click image for larger version.
ID:	258154 I am beginning to restore/restructure my old baja. i have the transom most of the way out. i plan to replace it and add some knees. i want to redo the floor as well. i have some questions however. is the tank placement in the front original? should i relocate it to the rear or leave it up front for bow weight? i could use the little storage that the closed bow provides. the boat ran great with the tank up front. i have no active trim capabilities so i'm concerned about planing off.
    Jan 2007
    Amityville/Lindenhurst
    Those little bajas worth anything? Had a guy come in with one that needed a transom i had no idea what they are worth
    Oct 2009
    Townville, Pa.
    ...it is to me. it belonged to a friend's dad. we skied on it for many years. i figure if i do the work, it will cost a couple hundred bucks. glassing boats can't be much different than glassing surfboards. i'm not intimidated by it. when it's done, it will be good for many more years to come.
    Feb 2005
    seattle
    you need to move the tank to the transom. its a speed stability issue. it will cause a slower hole shot but using cavation holes in the prop will eliminate the effect.
    the issue is the knees. no matter where they go there will be tank issues. do you need them yes, yes. either connect them to a rib or on a double floor[under the motor well].
    Oct 2009
    Townville, Pa.
    when you say "speed stability", how fast are you talking. i have no intentions of running this thing 60+ mph. is it an issue at 35-45 mph? it has aluminum trim tabs, if it makes a difference (turnbuckle style).
    Jun 2009
    Middle USA
    I have a friend with a 115 on a similar baja. it runs 45 without any set up at all... IM guessing it will run in the 50's if you want it to.
    L6fan57-88
    Oct 2006
    I have a 1974 Baja also with a 1974 85hp Merc with a 21p 2 blade that gps 47mph.
    Oct 2009
    Townville, Pa.
    it does. i have a 21 pitch on it. it goes. i want to prop it down a bit for wakeboarding and general play.
    Oct 2009
    Townville, Pa.
ID:	262393Click image for larger version.
ID:	262394Click image for larger version.
ID:	262395Click image for larger version.
ID:	262396Click image for larger version.
    i finally got some pics together. i have the deck back on the hull too. i'm trying to figure how to cap the transom and finish the job. any suggestions? i'll get some pics up.
    Oct 2009
    Townville, Pa.
ID:	262405Click image for larger version.
ID:	262406Click image for larger version.
ID:	262407Click image for larger version.
    May 2011
    MD eastern shore
    i just restored a baja 79 18ss i took the tank out the bow and ran tanks in the stern for a week i then put a 17 gallon tank back in the bow i couldnt drive the boat with out the bow weight. I suggest putting the tank back up front exspecially if you want to pull a wake board or ski. i love my little baja super light boat i have a 200hp 2.5 merc with 10 inch setback it is a fun 70mph boat i run a 27p 4 blade you may have seen my old posting on here it is gone now for some reason but it was the baja that was camo painted when i finished itClick image for larger version.
    79 Baja 18ss merc 2.5
    94 trophy 2352 (sold)
    85 checkmate enchanter merc 2.5
  12. #12
    Oct 2009
    Townville, Pa.
    i'm gonna try a set of jump seats (back-to-back so my ski spotter is facing the rear) with 2 six gallon tanks in the rear first. this will put some more weight forward. it did not have a bow tank from the factory. if i dont like it i will reinstall the original interior with a bow tank or trim tabs.
  13. #13
    Oct 2009
    Townville, Pa.
    here are some updates.
ID:	265653Click image for larger version.
ID:	265654Click image for larger version.
ID:	265655Click image for larger version.
  14. #14
    Oct 2009
    Townville, Pa.
    the transom has been heavily glassed. the seat frames are still in the mock-up stage. they will be sealed, faired, and glassed but removable. i may prefer the original interior layout but i had the loungers laying around so i figured i'd try them.
  15. #15
    Oct 2009
    Townville, Pa.
Name:	grass bottom.jpg
ID:	323962Click image for larger version.
ID:	323963Click image for larger version.
ID:	323964Click image for larger version.
Name:	pylon mount.jpg
ID:	323965Click image for larger version.
