Results 1 to 9 of 9
06-27-2012, 11:13 AM #1Junior Member
- Jun 2012
- cleveland ohio
97 merc 175hp xr2 sport jet crank and bearing specs info needed please
Hello there !
i have a 97 merc 175 sport jet engine that i will rebuild . i have a contact at SKF for the bearings
i have the top and bottom SKF bearing #'s . i need to know what is the SKF # of the rod bearings (large end) and the middle main bearings . If possible!!!
second i would like to know the measurements of the crank journals and wear limits.
I appreciate the info and any other advise that can be given !!
Thanks
Bart
06-27-2012, 11:18 AM #2
Welcome aboard !
I want to hear the answers myself.....(I'm not sure that you can get ALL the bearings from SKF)....probably the bottom bearing you can.....Maaaaybe the top one....?JOHN MASON
'83/VECTOR/MERC 200-- SOLD
'98 Quartershot T-3/ MERC 200
"If your not living on the edge, your taking up to much space"
06-27-2012, 11:33 AM #3Junior Member
- Jun 2012
- cleveland ohio
yeah i have those #'s already
even if you have used ones they must have a stamping # on it!!!
06-27-2012, 02:05 PM #4
Did you find that you can get ALL the bearings from SKF ?
JOHN MASON
06-28-2012, 06:55 AM #5Junior Member
- Jun 2012
- cleveland ohio
just the top and bottom !! still need the others!!
HELP!!!
also need crank specs
thanks
07-14-2012, 04:31 PM #6Junior Member
- Jun 2012
- cleveland ohio
????? ANYONE ??????
I just can't believe that there is no one that can tell me what the journal size of the mains and the journal size of the rods????
????? ANYONE ??????
07-14-2012, 06:28 PM #7Screaming And Flying!
- Jul 2002
- FT WORTH, TEXAS
- 8,031
- 9
- 146
- 313
- 503
you have to buy after market bearings or Mercs there are no generic rod bearings or main bearings, your not the first guy who tried to circumvent the system. buy a 25.00 caliper and measure them then you will know what size they are i build around 25 motors a year for outboards all V6 Merc Rod bearings cost me 17.00 each mains are 28.00 each ( i tried to convert bearings when i was building alot of lower units only found reverse gear was generic balance made for merc or aftermarket guys only)
07-14-2012, 06:44 PM #8
You have to be careful when getting the brgs, they will have a speed or rpm rating depending on what is used for lube ie. grease, oil, etc. The number may be the same but normally have letters at end of the number that determine speed rating. You don't want a crank end brg only rated for 2000rpm on the end of your crank, a good parts person should be able to get you the right one.
07-15-2012, 09:22 PM #9Junior Member
- Jun 2012
- cleveland ohio
i do appreciate the response !! thank you dave!! i have to get a crank rewelded due to pitting on journals would you have the specs on the journal size of rods and mains. the top journal is my main concern it is the worst !!
thanks
