Results 1 to 15 of 47
Thread: can i cheat a little w/a 300x
06-25-2012, 01:55 PM #1Member
- Apr 2007
- 93
hey guys i am in the final stages of getting my cougar back together and i was wondering,i ordered a new headgasket[spagettii]style but they are on backorder for about a week.my question is can i get away with some rtv high temp gasget maker?i wont be going over 4500 rpm and can i use a ngk br8hs i cant get champions here for any less than 40$ per plug and again it would take a week i am not trying to be cheap i just wanna go on our planned trip,and use my boat.thanks for any and all replies
06-25-2012, 02:27 PM #2Member
- Jul 2011
- FL
- 51
I dont know about the gasket but get your plugs at www.sparkplugs.com they are $7 each plus shipping, I got mine in 2 days from Cali to FL.
06-25-2012, 02:38 PM #3Member
- May 2012
- Montreal, Canada
- 50
RTV won't hold the cylinder pressures generated by the combustion.
It's made to seal water passages, oil, etc.. NOT a cylinder. You need that steel ring to hold the pressure or else you'll blow the seal real quick.
06-25-2012, 04:54 PM #4Member
- Apr 2007
- 93
um i dont wanna sound stupid but there was no steel ring only the spagetti gasket
06-25-2012, 04:55 PM #5Member
- Apr 2007
- 93
and also none of the spark plug companies will ship to canada
06-25-2012, 05:46 PM #6Member
- Apr 2007
- 93
also thanks for the quick reply any other ideas
06-25-2012, 06:27 PM #7
You can not use rtv to replace the o rings but you can use it to replace the spaghetti gasket. Lots of folks doing it. I dont know if they have them up there but i get my plugs from napa here. Cheapest ive found anywhere. And theres no steel in 3 litre head gaskets
Why does everyone keep calling me Richard Noggin?? My name is George!
Just bring some aloe.....ima tan that hide.......
06-25-2012, 11:35 PM #8Member
- Apr 2007
- 93
thanks hogg,i wont use the rtv for the o rings as i have new o rings,and napa does not have the champion plugs in canada and thanks for clearing up the metal gaskets
06-25-2012, 11:41 PM #9
Yes. As a matter of fact, why would you "waste" the money on the sketti o-rings in the first place. OMC's been doin that from the factory .. for years.
Now if your really in a pinch, you can take out the "viton {florocarbon} rubber" compression o-rings out. Put a small smear of RTV in the groove, put the o-ring back in up side down and go again ...
06-26-2012, 12:25 AM #10Member
- Apr 2007
- 93
thanks so much for the reply chaz,so can i use the ngk br8hs?
06-26-2012, 09:21 PM #11
I wouldn't put Champions in my lawn mower but I would give them to my competitor.
------------'82 Vector - Mercury 2.4 Bridgeport "MOD"
"Life is short - Get there fast...MERCURY"
06-27-2012, 07:08 AM #12
we use br8hs or br8hs10's all the time, gap them to .028 and go. you can use rtv on the outer perimeter of the head, just clean everything w/ brakecleen and you'll be fine
06-27-2012, 02:16 PM #13
90 + MPH ,BATHE IN MY ROOSTERTAIL
06-27-2012, 03:48 PM #14
have several of them running around w/ them
06-27-2012, 07:11 PM #15Member
- Apr 2007
- 93
wow thanks alot guys im going boating finally,fingers crossed
