Results 1 to 4 of 4
Thread: Gearcase Questions
07-16-2001, 06:00 PM #1
Can anyone give me a reason why Mercury has changed the production gearcases and went to a non ramped clutch dog type gear.
This seems like a bad design to me but someone please correct me if I am wrong.
My biggest concern is that upon a fast shut down or even an engine failure at top speed what will happen since the prop will no longer freewheel on the clutch dog. I really don't see this as being a problem on a tunnel boat but damn, I do believe this could make for some problems in a V-Bottom.
Also wont this put a lot of stress on the drive shaft as well as the crank shaft upon decelleration since it is now a direct drive and the prop will be getting dragged through the water without being able to rotate.
Any input will be greatly appreciated,
Thanks,
ED
fasteddie
07-16-2001, 06:24 PM #2
That’s news to me. I just built 2 CLEs and both gear sets were ratcheting. What part #s are the gear set and clutch dog you have?
07-16-2001, 09:59 PM #3
Eddie,Merc does not do this on the hi perf units or pro max series just for that reason.I ask while attending a class.Can I buy yo 2.5 say fer $26.00 and you pay da shipping? hf..
07-17-2001, 07:13 AM #4
Halfast, can this gearset be changed?
or is this a bastard case that only parts from other cases like it will work.
Why did they make this change?
The last 200 case I had still had the ramp style gearset and it always worked fine without a single problem.
I guess that this is one of mercury's better idea's???
Why change a good thing.
Maybe they just want to make them like OMC has for years.
fasteddie
