Results 1 to 4 of 4
05-30-2012, 09:21 AM #1Banned
- May 2012
- Stuart Florida
- 95
Small Mercury RPM range????????????
I have a 9.9 Mercury spinning a 10 pitch prop. Other than an actual tachometer to see your rpm's how can you tell it is within the Correct RPM Range? A 1993 model so is it a 4500 to 5500 on this? The sticker to find this I cannot read. Thanks, Ed
05-30-2012, 10:18 AM #2
I think if you are using it on anything other than a sea flea, it should stay within the rec. rpm. with the stock prop. on it,s own. Use full synthetic oil thanks.
free spirit / ONTARIO, CANADA.
05-30-2012, 11:33 AM #3
Merc says 5-6000rpm, used a shop meter to check mine. It runs 5800rpm with 9x9" on a light 12' aluminum hull with a 200lb driver and 3gal of fuel.
05-30-2012, 12:02 PM #4Banned
- May 2012
- Stuart Florida
- 95
