Results 1 to 4 of 4
    pontiac MI
    460 over heating
    I have a 1977 weirdt with a 460 and a Berkeley pump. When i got picked it up it had water logs one it. I only drove it a few times and everything seem to work good. It came with bassett headers so i installed them and hooked the water lines up the way they said. Well the next time i took it out. It over heated and threw a rod. I pulled the motor and installed a different 460 but it still over heating. I checked the hoses and they are not plugged i ran water out the pump to make sure the wear ring didn't spin. I am going to put the water logs back on but i cant see how that will make a different.
    This is my first jet boat and i cant seem to figure it out.
    Thanks Leroy
    Merritt Island FL
    This is the best plumbing info in print. Do not use the instructions that come from the header makers.
    http://www.performancejet.com/ttjetb...necooling.html
    pontiac MI
    Thanks i will give that a try. I hope that works. I thought with one 5/8 line coming in and one going out would be good?
    Merritt Island FL
    need one going in that T's into 2 and feeds water in each side of the water pump block off plate. Run two out the back one with a valve, my tub wants the valve 3/4 open to stay cool. Feed the headers off the intake may need to tap the hole that is on the front of the intake, in a car it had a nipple that was conected to the water pump. If they spray a light mist from 2000 up ur good. If you me 321-431-7459
