Results 1 to 15 of 66
Thread: More agressive sound...
05-25-2012, 07:40 PM #1Member
- Jul 2008
- Clever, Mo.
- 85
Engine is a bone stock 150 XR6...thoughts??
1997 Gambler Outlaw
Powered by Mercury
05-25-2012, 08:44 PM #2
Are you more willing to compromise the strength and integrity of your midsection, or spend over $1000 for an offshore mid?
05-26-2012, 06:59 PM #3Member
- Jul 2008
- Clever, Mo.
- 85
Well I'd like to hear my options without swapping to the os. mid...tuners??
1997 Gambler Outlaw
Powered by Mercury
05-26-2012, 08:13 PM #4
If you don't pull the liner and punch holes somewhere in the mid, it's not going to sound much different. Holes anywhere in the mid will weaken it and risk cracking or losing your lower unit.
05-26-2012, 08:23 PM #5Member
- Jul 2008
- Clever, Mo.
- 85
Hmm...well, how much will it help with pulling the liner and adding a tuner?
1997 Gambler Outlaw
Powered by Mercury
05-26-2012, 09:45 PM #6
It already has a tuner, and tuners have very little effect on sound quality OR performance on an outboard. It's a catchy name for a snout in a can. There have been a couple of documented instances where a tuner has broken completely off, and the only noticeable difference was a slight rattle at certain RPM's.
Pulling the liner by itself will give you nice white calcium streaks and burnt paint on your midsection.Last edited by pyro; 05-26-2012 at 09:50 PM.
05-26-2012, 11:02 PM #7Member
- Jul 2008
- Clever, Mo.
- 85
So, what was it about the old 2.4 bass motors and such that made such a better sound at idle? My 150 is almost silent and to me sounds down right weak...
1997 Gambler Outlaw
Powered by Mercury
05-27-2012, 08:20 PM #8
Unless you releave the exhaust above the water line it wont sound any different at idle. I have my mid drilled and it only gets loud once you get on plane and is still quiet at idle.
------------'82 Vector - Mercury 2.4 Bridgeport "MOD"
"Life is short - Get there fast...MERCURY"
05-27-2012, 10:11 PM #9
Ha ha, since when? They don't sound any meaner unless they're on the trailer on 'muffs'.
If I hadn't wasted all my time shooting photos of boats in action, I would have taken more photos of cracked midsections over the years. They always crack at the site of the exhaust relief holes. When the welder comes out and "fixes" it, it cracks again on the next run. Time after time.
If you take a "box structure" designed to handle massive twisting torque loads (with nice and even flex and force distribution), and you drill holes in it, twist it with engine torque, and beat it against the waves at high speeds, it will eventually fail, starting at the holes. If you weld snouts into the holes, you create a "stiff" spot, which moves the stress to adjacent areas of the casting.
You can put a HEAVY, expensive offshore mid on it and enjoy being harassed by the cops... or leave it alone.'89 Hydrostream Vegas XT, '90 Merc 2.4 Bridgeport PCU EFI
05-28-2012, 07:28 AM #10
I've had success with removing the can and drilling holes straight down at the bottom on each side of the original exhaust exit. This provides an aggressive sound with the least possible compromise in integrity. The holes are not visible since they are pointed down just above the cavitation plate. The down housing will run hot and crust up as you've removed the layer of cooling without the can.
06-04-2012, 10:50 PM #11
Does your motor vent from the eyebrows or does it have the centered rubber exhaust relief & sealed eyebrow holes? The motors with the eyebrow vents definitely sound better at idle. But don't drill all the way through those eyebrows or you will hurt your holeshot. You would need to remove only the outer layer of metal. If you run the smoothback offshore you can put the "muffler" in & not likely be bothered by the police.
HydroStream "Spirit of '76" Bicentennial Viper - '96 2.5 200 Pro Max, 15" smooth back mid, SM
'92 Allison 2003 Grandsport XS - 225 ProMax/20" mid & Sporty, 11" setback
Newish to me - 2002 StingRay 240LR with a Mercruiser 350 throttle body EFI 260 HP/Bravo 3
SOLD - 1989 Wellcraft Elite 220XL w/ Mercruiser 350 Magnum
06-04-2012, 10:54 PM #12
Oh, on my Bridgeport, I kept the inner liner/can but drilled several holes near the bottom on the sides right over the factory Merc Hi Perf holes in the exhaust housing. I never had to deal with the hazing of the mid like on the 260 or the Drag motors.
06-05-2012, 07:38 AM #13
Oh really? Perforating the end of the mid's "box structure" with holes on wither side of the area where the lower unit attaches won't weaken it? Whew! Good thing there's no sideways forces exerted by a lower unit in a surfacing application.
People always come on here to brag about their loud drilled mid, but nobody ever comes around to brag about it later when it cracks, and they eventually do crack. It's not "if", but when. Cycles of repeated force will eventually exploit the weakness. Just because it's popular doesn't mean it's wise.
...and before 1Bad comes on here to chew me out (since I've spoken out before against relieved exhaust), I really don't mind the sound of an opened-up motor. I've just come to believe that safety is more important that cosmetic vanity. Maybe I'm wrong, as I often am...'89 Hydrostream Vegas XT, '90 Merc 2.4 Bridgeport PCU EFI
06-05-2012, 12:04 PM #14
Think he's doin' tha same thing "MERC" does on tha Hi Perf bass mids. Tha 10 1/2" holes (5 per side) on tha horizontal flat part and no can.............
06-05-2012, 06:51 PM #15
