Page 3 of 3 FirstFirst 1 2 3
Results 31 to 44 of 44
  1. #31
    Jul 2009
    savannah,ga.
    Can't wait!
  2. #32
    Jul 2009
    savannah,ga.
    Got my skeg work done. Needs to be straightened out on the bottom and new torque tab added. Has same dimensions as a sportmaster but the angle may not be the same.
  3. #33
    Nov 2007
    Tarpon Springs FL/ Queens. NY
    There you go!
    Mirage RR
    Lake Tarpon Boyz!!!
  4. #34
    Jul 2009
    savannah,ga.
    Quote Originally Posted by BeefKid View Post
    There you go!
    I think you suggested that I do it. Since ya been there I thought it might be a good idea.
  5. #35
    Nov 2007
    Yeah I did it to both mine and my Merc case is even bigger lol
    Mirage RR
    Lake Tarpon Boyz!!!
  6. #36
    That should work, just make sure its strait.
    The stock omc skeg with a torque tab looks like this at speed, not good....
  7. #37
    Jul 2009
    savannah,ga.
    Thanks for the advice Baja. Guess I'm gonna have to run it to know what I've got. I can see that motor cranked to right steer. That's a common trick a lot of people have to use to stay hooked up. Hope this mod can let me track straighter!
  8. #38
    Jun 2008
    kingman az
    Quote Originally Posted by frederick55 View Post
    is it just me or does the cone on that look off?...might just be an optical illusion but it looks like the cone was put on slightly higher than the bullet....
  9. #39
    Jul 2009
    savannah,ga.
    It's about 1/4" higher than midline on the shaft. Supposed to add a little more lift. I have been running it this way and had no problems. I think what's making it look higher is where they took off some of the fairing on the bottom to make the weld. There are some sanding marks at the top that add to the illusion. It's just an illusion.
  10. #40
    Jul 2009
    savannah,ga.
    Finally got the flake cut & buffed. Flipping it over tonight. Got to get ready to go down to Sam's and pick up the Rude next week. By the way, Sam's birthday is next Tues. on the 6th.
  11. #41
    Jul 2009
    savannah,ga.
    Good thing I've done construction work most of my life! I'm used to doing things by myself.
ID:	280195Click image for larger version.
ID:	280196Click image for larger version.
ID:	280197Click image for larger version.
  12. #42
    Dallas, TX
    Looks awesome man!
  13. #43
    Nov 2007
    Mirage RR
    Lake Tarpon Boyz!!!
  14. #44
    Aug 2004
    kingdom of bahrain
    what is the best hight jack plate set up for 18 action marine??? my motor is 260 mercury 9500 rpm 24 yamy chopper
    its not always the gun its the man behind the trigger
