Page 2 of 2 FirstFirst 1 2
Results 16 to 19 of 19
    Sep 2002
    I took a nut-backed tire valve stem, removed the valve part, drilled out the ID a bit bigger, and ground off the threads on the last inch of the tip. I installed it into the side of the fuel filler neck for my return line. Works great.
    I'm NOT a big fan of the idea of using the spare IN port, as it closes the fuel loop and will re-circulate air bubbles if your fuel runs low and sucks up any air... This can cause a dangerous lean condition. The Vegas tank is wide, so it's possible to draw air occasionally in a turn.
    My setup has been the same way since 2006.
    Also, make sure your vent line makes a tall roller-coaster loop between tank and fitting to keep water from getting in.
  2. #17
    Jun 2008
    on the river north of Blarney
    i too have had troubles returning fuel to the seperater, i ran the return to the fuel cell and no more issues
  3. #18
    Aug 2004
    Venice, Florida
    Just doing a little research and came across this old thread via a google search. Moeller now makes a fuel level sender with a return fuel fitting in it.
    21' Paramount
    Mercury 300 Promax
  4. Thanks nitro_rat thanked for this post
  5. #19
    Dec 2011
    Ottawa
    http://www.cpperformance.com/p-74571...turn-port.aspx
    Quote Originally Posted by Hank W View Post
    Just an idea. Could it be because you are returning to the extra "in" port instead of the fuel tank that your fuel is hotter & causing premature failure. I've heard that people that constantly run their cars low on fuel have more than average pump failures as they run hotter. I run a separator before the pump, then an inline after, but I return to the tank. My Viper fuel tank does not have an extra fitting so I installed a tee in the vent & return down through it.
  6. Thanks nitro_rat thanked for this post
