Results 16 to 19 of 19
07-09-2012, 08:26 PM #16
I took a nut-backed tire valve stem, removed the valve part, drilled out the ID a bit bigger, and ground off the threads on the last inch of the tip. I installed it into the side of the fuel filler neck for my return line. Works great.
I'm NOT a big fan of the idea of using the spare IN port, as it closes the fuel loop and will re-circulate air bubbles if your fuel runs low and sucks up any air... This can cause a dangerous lean condition. The Vegas tank is wide, so it's possible to draw air occasionally in a turn.
My setup has been the same way since 2006.
Also, make sure your vent line makes a tall roller-coaster loop between tank and fitting to keep water from getting in.Last edited by pyro; 07-09-2012 at 08:28 PM.
07-09-2012, 09:59 PM #17
i too have had troubles returning fuel to the seperater, i ran the return to the fuel cell and no more issues
03-31-2018, 08:11 AM #18
Just doing a little research and came across this old thread via a google search. Moeller now makes a fuel level sender with a return fuel fitting in it.
21' Paramount
Mercury 300 Promax
nitro_rat thanked for this post
03-31-2018, 11:42 AM #196000 RPM
- Dec 2011
- Ottawa
- 1,365
- 33
- 47
- 20
- 72
