Results 1 to 2 of 2
    May 2008
    nashville, tn
    Exhaust hook-up help - CVX-21
    Finally have the motor mounted in the boat!
    455 olds with Berkley drive, CVX-21 '75
    The old "log-style" Hardin exhaust manifolds / risers are 3" diameter.
    The exahust "tips" are 2 7/8"
    The risers do not line up with the tips. There's an offset of about 2 inches. (port to starboard)
    The exhaust needs to be about 10" long (assuming a 1 1/2" overlap)
    Can someone suggest a flexible exhaust tube that can go between the risers and exhaust tips?
    I tossed the old exhaust tubes.
    I noticed that they were not straight, they were kind of deformed, cracked and generall worn-out . Now I understand why they were deformed. I thought it was going to be a straight shot from the risers back to the tips.
    I purchased the boat as a project and keep having these surprises.
    I had the same problem. I corrected it with wedges between the manifolds and the risers. I don't remember what direction mine was off, but it doesn't matter. Looks like this.
    As far as the tips.....you just need 3" tips. I can tell you how to enlarge the holes if you need help.
    Old
