Results 1 to 4 of 4
    Jan 2012
    South Carolina
    Question 1989 150 GT Johnson lower unit ???
    my Question is will a 89 150 GT johnson lower unit Fit on a 97 200 Venom mid?? the lower unit on the venom split after hitting some rocks lol and innihilated its self..so i have a 89 lower off of a 150 gt will it Fit any info would be Great Thanks!!
    "Get in Sit Down Shut Up And Hold on" OOOAH "
    Jun 2008
    kingman az
    im pretty sure it will...get ahold of racer, jenksam or instigator here on the boards any one of them would be able to give you a 100% for sure answer.
    Nov 2003
    Yes the case will bolt up. But the drive shaft is a lil shorter about a 1/4 inch if my memory is correct. I have seen it done but you should really change the drive shaft.
    Jan 2012
    South Carolina
    Alright thanks for the information .. i'll take a closer look at the drive shaft thanks again!!
