Results 1 to 2 of 2
    Mar 2012
    Bridgeport, CT
    Mercury 1997 225 (Carb) losing RPM's
    Hello,
    I have twin 225's (2stroke) with the port engine starting to act up. Starting does not sound good, spitting and coughing for a few mins the evens out. When at running (RPMís 4000) the port engine will lose about 400 rpms for a few seconds then advance back to where it was. It cycles through this about every 2 min. At lower RPMís 2000 or lower I donít have an issue. I have changed the plugs, fuel lines and filters. As for fuel there is only 1 220 gal tank that feeds both motors and the starboard engine does not seem to mind it. I read about a throttle speed sensor that controls the timing at higher rpmís. Could this be the issue?</SPAN>
    Jun 2009
    central minnesota
    ck the fuel press after the lift pump (square fuel pump)
