Results 1 to 15 of 19
Thread: convert HPDI to a OX66
02-08-2012, 10:44 PM #1Member
- Jun 2001
- north Al.
- 50
can a hpdi be converted to a ox66 I know the heads will fit and injection will bolt on but will it work I think it would probubly run lean because the diference in the 3.1 and the 3.3 any info would be appreceated
Mal
02-08-2012, 10:59 PM #2
Better off getting an ox66 drop on
02-09-2012, 09:54 AM #3Supporting Vendor
- Sep 2006
- Key Largo, Fl
- 3,272
- 215
- 30
- 585
no different blocks all around different crank too.
02-10-2012, 11:07 PM #4
Chris he is talking about a 3.3,been running a 3.1 on a 3.3 leg for years now
02-11-2012, 07:09 AM #5Supporting Vendor
- Sep 2006
- Key Largo, Fl
- 3,272
- 215
- 30
- 585
Eric,dose'nt the hpdi use a crank with different journal locations than the Efi motor?
02-11-2012, 07:26 AM #6
Nope...You can run a 3.3 front half on the 3.1 block with no problem.
Given the power that you can make from the 3.1 with stock electronics/fuel system I don't think you would have a lean issue (especially since the OX has an oxygen sensor)...but I don't see why you'd want to change...'08 SRV
Yamaha 3.1 Phase III
02-11-2012, 08:02 AM #7Supporting Vendor
- Sep 2006
- Key Largo, Fl
- 3,272
- 215
- 30
- 585
Dok,I stand corrected...the 90 degree ox66 and hpdi"s use different cranks,but the 76 degree motors aparrently share the same crank,whats the difference\exchangability between the 3.1 and 3.3?,Chris
02-11-2012, 08:26 AM #8
the 2.6 efi an hpdi use different cranks but the 3.1 an 3.3 ues the same! ive done lots of them!
02-11-2012, 08:32 AM #9
02-11-2012, 09:24 AM #101990 22' Activator Yami HPDI 300-sold-86.4
1976 21' Challenger 2002 3.1 Yami 250 Vmax phase lll 89.7-sold
1982 21' Superboat 300merc-87
1990 22' Activator yami OX66 Vmax 250-84.2
1982 30' Scarab-twin 200 Merc-sold
1979 21' Challenger 300 Evenrude-sold
1979 21' Superboat 200 Merc-sold-72
02-11-2012, 09:34 AM #11
02-11-2012, 09:49 AM #12
02-11-2012, 09:54 AM #13Supporting Vendor
- Sep 2006
- Key Largo, Fl
- 3,272
- 215
- 30
- 585
thanks all,chris
02-12-2012, 12:27 PM #146000 RPM
- Oct 2009
- Gonzales, La
- 1,085
- 114
- 69
- 218
- 355
Any idea how/why the HPDI doesn't have an O2 sensor?
02-13-2012, 10:14 AM #15Markus' Performance Boating Links:
