Results 1 to 6 of 6
    longisland ny lindenhurst
    Question nose cone on a 2hole cle?
    whats up guys,i got a 2 hole cle with a bobs nose cone on it.the cone is all beat up so im debating on putting a new lwpu back on it or run the cle without it.how good are those 2hole cle when pumping water at idle and WOT?i heard also the cone on the cle helps steering,is that right?the case is going on a sleekcraft.i got a 10-15min 5mph ride outta my canal.any advice would help.thanks
    edd
    16ft superboat
    14ft vixan
    15ft viper
    24ft sleekcraft
    21ft sleekcraft modvp
    18ft action hst drag
    18ft accelerator drag
    21ft redline
    18ft vking yt
    20ft Allison grandsport
    20ft laser 420
    18ft X-Stream Vking
    24ft banana
    Feb 2003
    Rochester, NY
    I have a 2 hole CLE on my 1992 Merc 200 and have no problems at idle unless I get into weeds. They can be the kiss of death with these things. I even keep a Torx driver and Pipe Cleaners in my tool box so I can jump in, remove the side plates and clean things out if needed. At WOT, if anything I have too mch water pressure.
    1992 Progression 22
    Mercury Racing 250R
    Stock CLE's seem to work best on hulls that do not need positive trim to get best top end, low propshaft height and positive trim scrub speed.
    well thanks for the info guys,but i knocked off that bobs nose cone that was on my cle and found something outta a horror movie.some1 who owned tis case b4 me chopped the damn cone off the cle,from the water pickup holes to the point is gone.lol.just my luck.now idk if u gotta do that to run a bobs cone on a cle or the guy was on drugs at the time.guess i gotta run a bobs lwpu now!
    16ft superboat
    14ft vixan
    15ft viper
    24ft sleekcraft
    21ft redline
    18ft vking yt
    20ft laser 420
    18ft X-Stream Vking
    24ft banana
    Jan 2008
    eatonton ga
    titus can make it pertee for ya lowh20.com
    You need to cut the cone off the case to fit the Bob's on. Take it to Ronnie Holzmacher in Bohemia to do it, you will NOT be sorry.
