Results 1 to 3 of 3
01-12-2012, 05:53 PM #1New Member
- Jan 2012
- Ct
Converting 20 inch opti to counter rotating
I have twin 20 inch Mercury Optimax engines on my boat , Mercury does not make a 20 counter rotating lower unit.
How would you proceed in converting one ? Is changing the driveshaft of a 25 inch counter rotating to a 20 inch an option ?
The boat is a 1982 Boston Whaler 25 ,twin 2007 Mercury 150 Optimax engines. Ran this boat with this setup for a year only trouble is a port turn at speed the boat doesn't lean into the corner, quite uncomfortable.
ThanksLast edited by JMM; 01-12-2012 at 06:01 PM.
01-13-2012, 07:19 AM #2
you can change the driveshaft but you must ck the pinion height(shimming). you could also buy an sei gearcase that is done already as well
01-13-2012, 07:24 AM #3New Member
- Jan 2012
- Ct
SEI does not offer counter rotating gear cases , that was my 1st thought they said they are hopeful to offer some in the future.
