Results 1 to 10 of 10
Thread: What caused this to melt?
12-20-2011, 04:31 PM #1
Come off a motor I burnt number 6 in. But, this is number 2 and it looks fine. Did a lean condition cause this?
12-20-2011, 05:32 PM #25000 RPM
- Melbourne, Florida
- 645
- 13
what does the top of the piston look like? From what I see it looks like detonation
12-20-2011, 05:45 PM #3
It looks fine. I even looked the head gasket over good. That melted part is by the exhaust port.
12-21-2011, 07:45 AM #45000 RPM
- Dec 2002
- Paulina, LA
- 821
looks like a gasket leak to me.
12-21-2011, 07:51 AM #5
12-22-2011, 09:12 AM #6Supporting Vendor
- 11,838
- 163
- 11
- 795
Could be that head made a dip there and had a leak like the others said, I've found big issues with some of the Mercury castings.. You cut and a small pin hole appears then the farther you cut the bigger the cavity becomes in the casting..
JayJay @ JSRE
12-28-2011, 03:37 PM #75000 RPM
- Jul 2003
- ga.
- 198
I.M.O. the sealing ring would have been burned if the gasket was leaking. leaning out can be a factor that going unsaid. it can be caused by heat saturation. an irregular surface where the heat saturates in the pores or chatter marks, bad castings. etc.
12-28-2011, 07:31 PM #8
I had a situation where a leaking head gasket ( water Leak ) caused cavitation burn from the boiling water (freshwater ) on the head , not as bad as that but similar .
01-01-2012, 07:23 PM #9
Can you show us the head gasket, both sides. Popey
Popey
01-03-2012, 07:28 AM #10
Already trashed the head gasket. It had no damage. It looked fine.
