Results 1 to 7 of 7
10-20-2011, 03:47 AM #1
4.0 Johnson V8 20 inch offshore mid convert to 25 inch mid.
Can I retain my existing gearbox from a 20 inch offshore mid by fitting that gearbox with a drive shaft and gear change shaft from a 25 inch gearbox and fit it to a 25 inch mid???? Reason is that the gearbox from the 20 inch leg has Bob's low water pickup etc already fitted.
Thanks.Wellcraft Nova 230 XL, 300hp Johnson.
Seahawk 45 Sport Fisher, twin 306hp Volvo.
Steadcraft 28, Yanmar 300hp. Sold.
Markline 800, Volvo 300hp. Sold.
Haines Hunter V19, Volvo 170. Sold.
16ft 6in Figlass Sidewinder, 140 Suzuki. Sold.
10-20-2011, 06:43 AM #2
Yes you can. If the lower has a 2 piece drive shaft , that makes it easy. Just get the 25" upper and swap. If not you have to take the lower apart, and change out the drive shaft , check shimming and reassemble. Shift shaft just unscrews and screw new one in but you have to set it to a specific height per the manual. I have a 25" drive shaft and a complete 25" V8 midsection with an offshore exhaust snout on it if you need one. Mid section is very clean, I think I have a shift shaft as well. Let me know
TimDrive It Like You Stole It!!
10-20-2011, 08:08 AM #3
10-21-2011, 04:20 AM #4Wellcraft Nova 230 XL, 300hp Johnson.
10-21-2011, 04:21 AM #5Wellcraft Nova 230 XL, 300hp Johnson.
10-21-2011, 02:39 PM #6Member
- Jun 2007
- 49
20" on a v6
hi will the 20" v8 mid fit a 235 v6 with convensional v6 drive. I have been looking at converting my v6 to have a v8 mid for a while as i want an exhaust snout etc. Are the adapter plates te same etc.
10-21-2011, 03:47 PM #7
