Results 1 to 3 of 3
    Nov 2010
    lakeland fl
    03 1/4master drag all composite forsale
ID:	244626Click image for larger version.
ID:	2446272003 1/4 master all composite bare hull weights 390. boat come with s3000 drag motor with a smilling jack intake, two mercury ecu programmed by brucato,12in champ mid section in out,up down, 2 gear cases one is a big case 2:1. the other is 1.87xr6 with custom carrier but has to be put together.10Gal race fuel cell lift fuel pump and hi pressure pump, 2 jc worked tru yamaha props,custom aluminun trailer,custom boat cover.. boat weights 1180 rigged with a 185 pound driver and 5gals of fuel. forsale $18500.00
    please call David @ 863-812-5968
    i will take more pictures when i get to my shop
    Dec 2004
    WINTER HAVEN,FL
    Did you buy the boat from RJ ?
    IT AIN'T FAST , IF ITS NOT ALLISOON MAN POWER!!!
    Nov 2010
    lakeland fl
    yes i did
