Page 2 of 2 FirstFirst 1 2
Results 16 to 20 of 20
    Apr 2023
    Long island, NY
    Wow!!! 5 hours total at 7K or less! And with bottom guided rods. You have convinced me. I will never ever be using Wiseco pistons in any motor I build.
  2. Likes NICE PAIR liked this post
  3. #17
    Nov 2020
    New Zealand
    I haven't got to that stage yet with wiseco pistons.
    This motor is running .009 clearance and it runs in cold water.
    The pistons show zero scuffing that would indicate that the piston ever good anywhere near either hot or cold sieze.
    On this basis I'd say that the Bore diameters could be pulled back at least a thou, maybe 1.5 thou.
    I'd never use them top guided with big clearance though.
    It's all about learning also.
    For example, based on what I've seen, I've changed my view on cooling.
    My view is now to run the cylinders with racing clearances cold,
    Pour that water in, use diverters of course.
    Keep water pressure under 20psi but increase flow.
    This will be how I run this season.
    Just my plan and not advice.
  4. Likes NICE PAIR liked this post
  5. #18
    Apr 2023
    Long island, NY
    Just curious, did you mic the Wiseco pistons before installing them? Or just after racing them for a season? Are you sure that the pistons are not ball shaped when brand new?
  6. #19
    Nov 2020
    New Zealand
    Always measure pistons first.
    The plus 20 piston started life at 3.514 across.the widest skirt.
    The recommended bore for that piston is 3.521
    7 thou total clearence.
    I have just now measured a new std wiseco same part number red box
    Widest skirt is 3.493
    Bore for that piston is 3.501
    8 thou total clearence but the piston is very cold so might gain half thou and have 7.5 thou clearance.
    Point of this is to show that the plus 20 piston was within manufacurers spec.
    After the seasons use that 3.514 measurement was less than 3.510 with no visible wear.
    I've now knurled them back out to 3.513.
    May be ok in a fishing motor
  7. Thanks wolfgangb thanked for this post
    Likes NICE PAIR, wolfgangb liked this post
  8. #20
    South Africa
    Sidewinder, pse send me a pm on wbarthel33@gmail.com. I have been in correspondence with Wiseco regarding the problem and did receive a response. I cannot for legal reasons publish the response here, but can send it to you as a pm.
    I am building a 4 cyl Force `98 model to spool to 7200rpm, piston and sleeve ported, very high comp, OMC 4stage twin throat carbs. Also bought a set of Wisecos - when I looked inside, I now decided to reuse the original pistons (which had not even 10 hrs run-time). Seller in US sold motor presumably because during original assembly, Loctite had seeped into the top main (ball) bearing.
    Rgds, Wolfgang (South Africa)
