Results 1 to 10 of 10
10-01-2011, 12:44 PM #1New Member
- Jun 2011
- Pearland, TX
2002 Evinrude 225 HO Fitch Questions
A couple of questions regarding this engine. It is on a boat I am interested in seeing.
Are these generally reliable?
Are these OK for use in saltwater? I would be using it halftime in salt and fresh.
Would the lower unit need to be pinned to run up high?
thanks
10-01-2011, 01:04 PM #2
10-01-2011, 09:33 PM #3New Member
- Jun 2011
- Pearland, TX
Thanks for the reply. I looked up some info on the lightning lowers. It seems they have mixed reviews. What are your feelings about the lower unit when running high?
10-02-2011, 09:18 AM #4
My old stock OMC case ran for 8yrs surfaced and beaten on hard with big props and weight all the time. Plus the last few yrs it had 300+hp on it and 8k+rpm and it held together fine. Never had a gearcase problem except when i found 4 ft of fishing line in the propshaft seals. If I was you I would pin it and avoid shifting it running if your really worried about it. Your not gonna be able to run it as high as you think with out a lwpu.
10-05-2011, 07:51 PM #5
Ive been running lightning gc and L2 gear case for quite a while now on a mirage ski racer. There not bad pushing a light weight boat, keep a close eye on that gear lube though. ficht engine not bad either ive had 3 of them 3.3 and 3.0 litre. Make sure you have a good shop that knows how to work on fichts though!
10-05-2011, 07:59 PM #6
10-05-2011, 08:19 PM #7
no cone its on a e tec 225 ho,ive been thinking about cutting off that factory nose and installing a bobs though!
10-05-2011, 08:31 PM #8
I dont think you have to cut it. Put a torque tab on the skeg and a bobs cone on it you will love it. The larger "wing" shaped skeg on the L2 keeps steering torque down alone then add a torque tab and you will have no steering torque and the case will go through the water strait = speed. How fast have you been? I'd love to see some pics, I have an etec thats going on my t1 soon
10-05-2011, 08:42 PM #9
95 is as fast as ive had it, high gear ratio on the L2 seems to help, running the gear case deep w the stock water intakes is holding me back I think.New to the forum ill try to get some pics of the mirage and other toys up soon. That boat on your profile picture looks familar i think i know the guy that used to own it
10-05-2011, 08:53 PM #10
