Results 1 to 15 of 18
09-13-2011, 08:53 PM #1
v6 crossflow interchange with v4 crossflow midsection and driveshaft?
Will a v6 crossflow drop on to a v4 crossflow midsection? Is the v4 driveshaft the same as the v6? Thinking of swapping powerheads if the v6 would fit? Thanks
2004 Checkmate Pulsare Bowrider
2008 Mercury 300XS
91.7 - MPH
88' Hydrostream Viper
86' Carbed Bridgeport
102 - MPH
09-13-2011, 09:51 PM #2
Not that it will help, I,m guessing no. The reason is the prop shaft is fatter, i,m assuming the drive shaft will be also. [..Warning this is not affirmative thanks].
free spirit / ONTARIO, CANADA.
09-14-2011, 04:40 AM #3Screaming And Flying!
- Jun 2007
- Singapore/Melbourne/Italy
- 9,109
- 1010
- 356
- 4327
- 1976
- 8 Post(s)
v4 single exhaust and v6 has 2
drive shaft the same spline
09-14-2011, 07:52 AM #45000 RPM
- Jul 2008
- Key Largo, FL
- 352
You just have to change the exhast adapter and it will work. You should change to a v6 gearcase too though to get the right gear ratio and prop.
86 18ft Motion (Action copy)
98 Quartershot T-3
09-14-2011, 08:35 AM #5
thanks
2008 Mercury 300XS
91.7 - MPH
102 - MPH
09-14-2011, 09:06 AM #6
It,s usually good to have more input and opinions that will likely follow thanks.
09-14-2011, 09:15 AM #75000 RPM
- Jul 2008
- Key Largo, FL
- 352
09-14-2011, 09:18 AM #8
yea, I'm going to run the v4 case if I go that route.
2008 Mercury 300XS
91.7 - MPH
102 - MPH
09-14-2011, 09:22 AM #95000 RPM
- Jul 2008
- Key Largo, FL
- 352
What boat do you have?
98 Quartershot T-3
09-14-2011, 09:33 AM #10
Vandal
2008 Mercury 300XS
91.7 - MPH
102 - MPH
09-14-2011, 09:40 AM #11
Reason, apparently 84 was first year switched to v6 lower assembly onto v4s thanks.
09-14-2011, 10:02 AM #125000 RPM
- Jul 2008
- Key Largo, FL
- 352
Your gonna need a lot of pitch with that lower. But yeah, the exhaust adapter with the attached tuner is the only differance in the v4 and v6 mids, oh yeah the cowling also.
98 Quartershot T-3
09-14-2011, 10:11 AM #135000 RPM
- Jul 2008
- Key Largo, FL
- 352
I know sometimes the v4 came with a v6 case. How many splines is the prop shaft. 15 spline 1.86:1. 13 spline small case 2:1.
98 Quartershot T-3
09-14-2011, 10:14 AM #14
Very true on alot of pitch. I don't think I want to drive this boat much past 80-85 though.
2008 Mercury 300XS
91.7 - MPH
102 - MPH
09-14-2011, 10:21 AM #155000 RPM
- Jul 2008
- Key Largo, FL
- 352
