Results 106 to 120 of 130
Thread: OMC Cross Charge Mod questions
10-11-2012, 05:19 AM #106
It makes lots of additional power in the mid range, very impressive. Top end is unchanged. I have a deceleration seizing problem that is quite puzzling. It's done it three times now. I'm sure there is damage so I'll be switching back to the stock block while I repair the damage and start over.
10-11-2012, 12:27 PM #1075000 RPM
- Nov 2001
- 106
Push your choke button in during decleration.
10-11-2012, 01:30 PM #108
I've heard the choke button approach many times and I'm sure it's a very good idea. However, I have a couple of suspicions that may be contributing to the failure. I will switch to an electric fuel pump as I feel the lack on block positive pressure may be limiting the pumps ability to deliver under light load deceleration. Also, my water pressure pegs the gauge since I added the LWP to the lower unit. I'm wondering if it could possibly be over cooling the block and causing the cylinders to clamp down on the hot pistons. I'll work on a relief to keep the LWP from boosting my water pressure. I say it's puzzling because I did this same thing with a Force 85 that had no failures in four years. It had an electric pump from day one and pickups that did not force feed. This could be one of those mountainous mole hills but I've got to try something. I want to reduce wrenching and increase drive time.
10-11-2012, 02:55 PM #109
A better option for the water pressure would be to block off some of the water inlets on the nose cone (like the two outer ones) for less drag. It usually makes a noticeable difference in top speed.
NRA Life Member
58' Farmall Cub
Is that your mama's boat?
"I said I didn't have much use for one. Didn't say I didn't know how to use it."- Mathew Quigley
10-11-2012, 03:35 PM #1105000 RPM
- Feb 2012
- Canada
- 346
10-11-2012, 06:27 PM #111
The jetting is Stock but that could be lean.
10-11-2012, 09:37 PM #1125000 RPM
- Feb 2012
- Canada
- 346
01-26-2018, 05:59 PM #113Screaming And Flying!
- Feb 2015
- Ontario
- 8,091
- 205
- 321
- 1921
- 2005
Spybot
01-28-2018, 06:32 PM #114
01-28-2018, 07:17 PM #115Screaming And Flying!
- Feb 2015
- Ontario
- 8,091
- 205
- 321
- 1921
- 2005
Some good info, found another with some good pics of a V4 chest modded nicely.
Leave duration about the same and it sounds like it runs right out of breath. Plenty V4 xflows run more rpm, as I'm sure you've read.
02-22-2018, 05:59 PM #116
02-22-2018, 06:17 PM #117Screaming And Flying!
- Feb 2015
- Ontario
- 8,091
- 205
- 321
- 1921
- 2005
I did, just don't know where lol
Maybe I can find it again. What happened to that link.
02-24-2018, 11:53 AM #118
Well I just read this whole thread.In my experience 135 & 140 heads are the same with a snap-on and a sears comp gauge I gets 135-140 how you getting 155 I don't know are you shaving the heads? even with my 140 shaved heads its 135-140 psi ? You need to run an elec fuel pump. Also my motors are all dry stacked no stats no popetts dump the head hoses right out the pan. Timing at 26 @ 7000 have seen 85 mph with 26 cleaver on 15 ft pacecraft and 16ft Allison in rouny round race set-up carbs 1-3/8 or 1-5/16th with 67 or 68 mains of the 10 mod motors [ 9 pages] never had one blow up or score a piston and racing back to back 10 mi heats its wot except in the turns. jm2cents?
spybot liked this post
02-24-2018, 12:00 PM #119
Oh and that's running 91-92 non oxy pump gas.
02-24-2018, 07:14 PM #120Scream And Fly VIP
- May 2001
- Hickory NC
- 5,583
- 18
- 250
- 204
- 464
- 4 Post(s)
The 73 135 heads had a larger deflector on the exhaust side than any of the 140 heads. I have seen 150 plus on many early 135s using snap on gauge cranking at 250rpm
