Page 7 of 9 FirstFirst 1 2 3 4 5 6 7 8 9 LastLast
Results 91 to 105 of 130
  1. #91
    Jun 2010
    hubertus
    I run 27 degrees timing with my ported v4 with 150psi but I ran 1/2 111 octain and 1/2 93 octain.
    1981 Hydrostream Vandal W/ evinrude 16" gt150
  2. #92
    Jun 2010
    hubertus
    is anyone looking for a v4 with 3.625 bore?
  3. #93
    May 2009
    Valrico Florida
    I didn't expect the compression to be that high and I fear another failure. I prefer to use pump gas and avoid exotic blends to ensure survival. I was reluctant to disassemble the original 140 long block because it is original and runs well, however I may pull the heads off that block and put them on this one so it will survive past the break-in. I can't find any numbers on the heads currently on the motor but I wonder if they might be the '73 135's. It seems really high.
  4. #94
    Sep 2010
    Left Central, Florida
    Does this mean the first one likely died of insufficient octane Tracy?
  5. #95
    May 2009
    Valrico Florida
    Not sure, but if you look at the existing damage in the heads and historic application, there's been multiple failures. You motor was timed at 22 and it melted down, supposedly from a faulty switch box. Maybe not. I really don't want to do that again. I ran the stock 140 flat out for eight miles more than once at River Ranch. Safe to say these heads passed the test and that was at 28 degrees.
  6. #96
    Apr 2009
    The Peoples Republic of Massachusetts
    Most stock cross flows run between 95 and 125psi compression.
    Very interesting thread.
    John
    NRA Life Member
    58' Farmall Cub
    Is that your mama's boat?
    "I said I didn't have much use for one. Didn't say I didn't know how to use it."- Mathew Quigley
  7. #97
    Sep 2010
    Are the original heads from the "free" motor (the ones going on mine) the same as the heads from your stock 140?
  8. #98
    May 2009
    Valrico Florida
    Quote Originally Posted by Cavit8 View Post
    They appear to be the same displacement without actually cc-ing them.
  9. #99
    Apr 2010
    Vacherie, LA
    Quote Originally Posted by bruzercomp81 View Post
    930, I agree w/ racer & bruzer in that I'm pretty sure that your going to need more than 93 octane w/ that much compression. I think I'd start w/ the lower compression heads if you want to stay w/ pump gas. Just my two cents... BTW, I'm happy to see you back in action!
  10. #100
    May 2009
    Valrico Florida
    Quote Originally Posted by Superstocker View Post
    I just finished changing back to the stock 140 heads - and confirmed the high compression heads are from a '73 135. Thanks guys for all the help.
  11. #101
    Apr 2010
    Vacherie, LA
    Quote Originally Posted by 930turbo View Post
    ~20-25lbs. compression difference?
  12. #102
    Oct 2003
    Cobourg, ON
    Depending which heads he put on, it is easily possible. Some heads net only 90-100 lbs.
  13. #103
    May 2009
    Valrico Florida
    30 pounds difference.
  14. #104
    May 2009
    Valrico Florida
    Quote Originally Posted by Riverman View Post
    I run the tight heads (317848/849) on 91 with no issues.
    These are the heads I just removed that had 152-156 PSI compression.
  15. #105
    Shreveport, La.
    Any updates on this motor?
    DB
