Page 5 of 9 FirstFirst 1 2 3 4 5 6 7 8 9 LastLast
Results 61 to 75 of 130
  1. #61
    Alabama
    When you get the jetting close you need a choke button on the steering wheel or somewhere close so you can choke it before you lift the throttle. I could run mine flat out for a half mile set up for drag racing but if I lifted without hitting electric choke it would burn one everytime. That might not be your case but it is definitely food for thought.
  2. #62
    May 2009
    Valrico Florida
    Riverman, the carbs looked great, 73 mains in all. The best I can tell, it’s a ’76 135 power head with the horseshoe type ignition – one pack. The water deflectors are in place and in good shape. </SPAN>
    Riverratt, this is what I suspect. Did you rebuild again and replace the pack? If so did the problem go away? I had to change the timer base because it mysteriously lost spark on two cylinders after sitting on the bench during the rebuild (same side as the failure). I did not replace the pack.</SPAN>
  3. #63
    May 2009
    Valrico Florida
    Interesting point Freddie, it did stick during the lift. However, the jetting appears to be stock according to all the resouces I've reseached for the '76 135.
  4. #64
    NE Louisiana
    Quote Originally Posted by Freddie Webb View Post
    I've never had that happen on a crossflow.
    Since you did all the porting work, maybe a couple size larger jets would be in order, at least to start with. You need to set your timing at 4500 RPM or so and under a load as Jeff mentioned.
    Did it just stick, or did it burn off the corners of the defector then stick?
  5. #65
    Oct 2003
    Cobourg, ON
    If you decide to switch to the later two-pack ignition system you will need a set of coil brackets like these. Let me know.
  6. #66
    NE Louisiana
    Great idea Jeff. Love the flywheel too! That's trick!
  7. #67
    Dec 2001
    Sunbury, Pa
    Yes I rebuilt it and changed the pack and it was fixed. Mine had the 2 packs but I chased it for a long time. I set the timing based on that cylinder and backed it down plus fattened the jets and still blew it up. Changed the pack and it was good to go. Like mentioned above I always set the timing in the water at around 5000 rpms.
    Ralph Musser
    27' Fountain Fever W/ 525SC
    22' Rapid Craft W/ Evinrude 300 V8 January 2009 BOAT OF THE MONTH SOLD
    24' Triton 240 Gold W/ Mercury 60
    14' Royalcraft W/ Evinrude 75 father/daughter project
  8. #68
    May 2009
    Valrico Florida
    Forkin', there's metal on the plug. That's as far as I went. I'll assume meltdown. What number am I looking for @4500 RPM under load? I set it at 22 cranking speed. Jeff, you've got the coolest toy.
  9. #69
    Sep 2010
    Left Central, Florida
    Quote Originally Posted by Riverman View Post
    Sexy!
  10. #70
    Oct 2003
    Cobourg, ON
    Quote Originally Posted by Forkin' Crazy View Post
    Yeah, but did you notice the titanium bolts?
  11. #71
    May 2009
    Valrico Florida
    I have a bicycle covered with titanium bolts. It adds great contrast to the carbon fiber everything else.
  12. #72
    Oct 2003
    Cobourg, ON
    Quote Originally Posted by 930turbo View Post
    If it's just the one cylinder I bet it was double firing as mentioned, Freddie is the man to get good info from. I drag raced mine at 28 degrees this year, ran the river at 26.
  13. #73
    May 2009
    Valrico Florida
    I guess another way to ask this question, what additional advance should I expect between cranking speed and 4500 RPM's. My past experience was there was little to nothing between the two. I also don't understand the full load deal. There's nothing load specific with relation to the advance mechanism on these things that I'm aware of. No vacuum related compensations. I free rev should produce the same results, shouldn't it? I believe the factory recommended setting is 26 degrees. It had 18 degrees when I checked it after the first melt -down. The stop turned way in. I brought it up to 22 degrees. I still think there must be something changing because of how hard I drove it so many times without failure. No hint of hesitation, full throttle runs with the exception of the chicken-ness that cause the brief back pedalling to save my @$$.
  14. #74
    May 2009
    Valrico Florida
    Cavit8, I just so happen to have a spare healthy 140 sitting in the garage. It's yours once you get the boat buffed out.
  15. #75
    Sep 2010
    First time I've smiled in about 24 hours... Ratcy, you are the best!
