Page 9 of 9 FirstFirst 1 2 3 4 5 6 7 8 9
Results 121 to 130 of 130
  1. #121
    Jun 2017
    fife scotland
    Is there a point where too much compression is bad for the engine ??
    What is the ideal range to try and hit say 130 psi +/- 5psi ?
    If you wanted a strong mid range motor what would you go for ?
    I love my Bikini
  2. #122
    Quote Originally Posted by spybot View Post
    Where's my popcorn?
    This should be interesting ...
  3. #123
    [QUOTE=spybot;3023809]Is there a point where too much compression is bad for the engine ??
    Nahh
  4. #124
    8 Post(s)
    Like racer I have seen many 135's over 150psi especially after a rebore
    There is a SAE paper on the Japanese testing comp, at about 18,000rpm it needs to be reduced.
  5. #125
    Different application but still xflow, above 195psi cranking too far was shown to hurt high rpm ability, meaning didn't hit the same rpm or rate of climb . That info came from a factory R&D man back when.
  6. #126
    I have a "different application" smaller bore Merc crossflow with significantly higher cranking compression; I get pretty good rpm and fantastic acceleration/rate of climb, acceleration much greater than stock and at least the same top rpm as stock compression motors, so I am not blaming compression for limiting my rpm. Looking at stuff that may be limiting the stock motors and working around that.
  7. #127
    It wasn't the low and mid which suffered, but just the top end in that example. The max was about 205-210 range , which was about 10-15 over stock, low and mid wasn't hurting. Likely increasing dynamic pressure values at high rpm vs over rev hp curve I believe was mentioned.
  8. #128
    Jun 2017
    fife scotland
    I think this will be a good thread so will start up a new thread on the subject.
    Sorry Mod
    Not ment as a double post.
    I love my Bikini
  9. #129
    Someone was mentioning coil mounts. Xflows v4, some nice ones in this thread.
  10. Thanks powerabout, hq_ thanked for this post
  11. #130
    Jul 2004
    Summerville,SC
    Yeah I’d love a set of those coil mounts for my build
