Results 1 to 15 of 130
Thread: OMC Cross Charge Mod questions
09-04-2011, 01:28 PM #1
I'm considering massaging a '77 140 and I'm looking for some advice/photos of mods I'd seen many years ago. Does anyone have photos of the CCC transfer port area where it appears an end-mill was used to remove a portion of the cylinder (upstream at the bottom) and near matching crescent cut out of the piston skirt? (to improve transfer flow). Any advice on total timing advance with the OEM heads and 93 octane pump gas? (removing melted piston now)
09-05-2011, 07:43 PM #26000 RPM
- Oct 2003
- LAGRANGE, IL
- 1,277
- 11
- 14
09-07-2011, 04:33 PM #3
Off topic, but I wish someone would post pictures of each of these ports on OMC, yammie and merc engines, along with what they do. You know, boost, transfer, intake, exhaust. Be interesting to have it all in one place.
09-12-2011, 04:47 PM #4
You talking about this. http://www.screamandfly.com/showthre...w-Thread/page2 9 page in this thread
09-13-2011, 04:20 AM #56000 RPM
- Oct 2003
- LAGRANGE, IL
- 1,277
- 11
- 14
Yes, that's the thread.
09-15-2011, 09:31 AM #6
Limiter
How do you know if your pack has a limiter? 1977 140
09-15-2011, 09:48 AM #7
What is the consensus for the end horsepower of an old 235 cross flow after the mods in the "9 pages" are completed?
....just planning for the future.
09-15-2011, 10:10 AM #8Screaming And Flying!
- Oct 2003
- Cobourg, ON
- 7,194
09-15-2011, 03:20 PM #9
I appreciate your feedback. What was your set-up? I have a Viper II. I'll apply the 9 pages during the rebuild of my 140. The rig came with a 14X30 Chopper I, I hope it'll turn it.
09-15-2011, 04:48 PM #10Screaming And Flying!
- Oct 2003
- Cobourg, ON
- 7,194
I'm running 5" of setback with the prop about 1/2" above the pad and a 14 X 30 cleaver. I have been to 80 with this setup.
09-27-2011, 08:48 AM #11
09-27-2011, 08:39 PM #12
Man that looks GOOOOOOOOOOOOOOD!!!!!!!
09-27-2011, 09:13 PM #13Scream And Fly VIP
- May 2001
- Hickory NC
- 5,583
- 18
- 250
- 204
- 464
- 4 Post(s)
I hope you have a good chamfer on the top and bottom of each port, The corner radius is tight. The 9 page deal is for race engines, I would recomend using 5/8 to 3/4 cutter on lake use engines for better life. We down to as small as 3/8 and the power difference is minimal.
09-27-2011, 09:37 PM #14Screaming And Flying!
- Oct 2003
- Cobourg, ON
- 7,194
I don't understand the mod to the bottom of the transfer area - it's not clear to me where the 1.375 dimension is measured from, and at what angle.
09-27-2011, 10:35 PM #157000 RPM
- Central Florida
- 2,644
- 37
- 32
- 219
Jeff - The section cut across the bottom of the cylinder inside the transfer port is specified to be 1.375" from the block parting surface. If you were using a vertical milling machine you would setup with the block on its back with the cylinders pointed down at a 45 degree angle. Then use an endmill to remove the top section of the cylinder inside the transfer port until it is 1.375" below the parting surface. Since the cylinder is on an angle the section cut off forms a curve. People do this to any number of other dimensions and shapes.
The "9 pages" intake and exhaust porting both specify a 1/4" diameter cutter. When I first saw this I wondered if that was supposed to specify a 1/4" radius for the port corners which would be made with a 1/2" cutter.
