Results 31 to 45 of 55
Thread: Optimax 200 spark plug
09-26-2011, 02:26 PM #315000 RPM
- Jan 2008
- CYPRUS
- 237
I'll do that ,the fuel injector can be easily removed!
Thank you.
09-26-2011, 02:28 PM #325000 RPM
- Jan 2008
- CYPRUS
- 237
Does anyone have a picture of how the spark plugs on an Optimax should look like?
09-27-2011, 11:59 AM #33
09-29-2011, 05:16 PM #345000 RPM
- Jan 2008
- CYPRUS
- 237
Thank you , i'll let you know what happened.
09-30-2011, 02:10 PM #355000 RPM
- Jan 2008
- CYPRUS
- 237
I forgot to mention that when i did the compression test and put the spark plugs back in i started the engine and an alarm sounded .
On the smart craft it says that the horn doesn't work but the horn keep sounding all the time!
Does anyone know how can i fix this problem?
10-07-2011, 12:11 PM #365000 RPM
- Jan 2008
- CYPRUS
- 237
Anyone?
10-09-2011, 11:43 AM #375000 RPM
- Jan 2008
- CYPRUS
- 237
10-10-2011, 01:08 PM #38
I just came upon this thread, and I see #6 as normal and #5 as rich and oil soaked thanks.
free spirit / ONTARIO, CANADA.
10-10-2011, 01:13 PM #395000 RPM
- Jan 2008
- CYPRUS
- 237
Only #6 is like that,all the rest are the same.
10-10-2011, 08:13 PM #40
What year is this motor, and how long have this set of plugs been in service? Some don,t like champion if those are,I,m not impressed with the yucky black coating on #5 of 5 . Are you running rich oil, cheap oil, I,d try a new set and monitor closely. This is my opinion only thanks.
10-10-2011, 11:52 PM #415000 RPM
- Jan 2008
- CYPRUS
- 237
Thank you Terry for your reply.
Year is 2007, spark plugs are in service for about 30 hours (NGK), i never used other oil than Mercury,s DFI and the engine doesn't use too much .
Can anyone tell me what to do about the horn problem?
10-12-2011, 04:02 PM #425000 RPM
- Jan 2008
- CYPRUS
- 237
Still no answer
10-14-2011, 11:41 PM #435000 RPM
- Aug 2009
- GA.
- 108
Your running leaner on the #6 cylinder than the #5 cylinder. The filter in the injector must be getting dirty. Pull the injectors and have them cleaned by brucato or hydro tec. They will test the injector before and after cleaning the injectors. They will pint out the results of each injector. So you can see how each injector come paired.
10-14-2011, 11:49 PM #445000 RPM
- Aug 2009
- GA.
- 108
If I was setting the fuel up on your motor I would set it like the #6 plug. The #6 looks good to me and others are rich.... But to get the plugs the same you need to get the injectors cleaned.
10-15-2011, 12:53 AM #455000 RPM
- Jan 2008
- CYPRUS
- 237
So i have to clean the injectors , i will do that.
What about the problem with the horn?
Thank you for your help.
