Results 46 to 55 of 55
Thread: Optimax 200 spark plug
10-15-2011, 05:35 AM #465000 RPM
- Aug 2009
- GA.
- 108
10-15-2011, 06:38 AM #475000 RPM
- Jan 2008
- CYPRUS
- 237
Thank you.
10-15-2011, 11:04 AM #48Banned
- Oct 2009
- cold lake
- 165
Is the engines oil reservoir topped up all the way?
10-15-2011, 11:42 AM #495000 RPM
- Jan 2008
- CYPRUS
- 237
It's about half full.
I recieved an email an hour ago and i got an answer about the horn problem.
The problem occured when i made the compression test.Some optimax models when you crank the engine with the kill switch to OFF they built up and trap electricity in the starters solinoid and then when you crank the engine with killswitch to ON this current travels through the 14 pin harness into the ECM and shorts the horn's circuit.
That' why the horn sounds all the time.
Solution? a new ECM .
10-15-2011, 10:24 PM #505000 RPM
- Aug 2009
- GA.
- 108
10-26-2011, 03:42 PM #515000 RPM
- Jan 2008
- CYPRUS
- 237
Good news, Mercury will send me a new ECM for free even though the engine's guaranty expired 6 months ago!!!
10-26-2011, 05:59 PM #52
10-27-2011, 10:54 AM #535000 RPM
- Jan 2008
- CYPRUS
- 237
Yes i did.
Is that going to be a problem in any way?
10-28-2011, 07:39 AM #54
Usually if a coil on a opti is bad you will know by the potting melting out I would ckeck you feul/air psi should be 8o air an 90 fuel , if there reading the sam it would mean you have a torn diapgham in the tracker valve or fuel regulater that will cause them to run lean, an checking the coils with a meter will only tells you its not shorted out , find some one with a ddt to do a miss fire test then fire each on injector the tips some times get stuck you will know because it will not click as loud as the other good cylinders , hope that helps .
10-28-2011, 02:38 PM #555000 RPM
- Jan 2008
- CYPRUS
- 237
I did a check with the DDT and everything seems to be ok at least electrically.
The only thing i haven't checked yet is the fuel/air pressure.
Thank you.
