Results 1 to 15 of 16
Thread: Short Trim Ram
    Mar 2004
    Lexington SC
    Short Trim Ram
    Does anyone know where I can find any info on cutting down a long trim ram to the short drag style I see alot of post on here about doing it but nothing telling anything about it ???
    Dec 2012
    HUDSON, FLORIDA
    Quote Originally Posted by dbug10 View Post
    i made one and turned into a huge project because of incompetent persons doing there part. cutting the barrel is not difficult i was talked into cutting piston rod under cross pin tube removing section re-welding instead of going from bottom up piston assembly un screws then cut rod section and re-thread o ring doesnt passover barrell cut if u measure correctly. do not cut rod at pivit end yoke must be exactly square and centered or side ss pins will not go in. after all effort an$$$$ still need wedges to get neg motor tilt. the merc race ram is best buy if you have money to burn. i learned my lesson......
    Mag ,
    Honestly man , I'm not sure which is worse ;
    #1 You responding to a six year old post .
    #2 Giving false advise off of a bad experience .
    A properly cut cylinder will tuck under the front of the cavitation plate , going full negative trim .
    Where they are limited is in extension . They will still go out at a 45* degree angle , which is more than enough to get the prop and skeg out of the water .
    I have no less than a dozen cylinders in the shop right now , and not one of them has a good top loop . This one was reusable . I cut the bottom of the block (loop) square and cut the shaft square on a lathe . One would have to have a pretty bad day to glue it on crooked ..
    Not all , but many look like this .
    Before you say they should be cut at the bottom and rethreaded , you really should cut both ends off of the shaft and see that it's actually a solid steel bar inside of a stainless tube , and what it would take to machine it .
    I didn't understand what you meant about the O-ring catching . I install a new set of rings , seals and wiper on each cyl , so far , no issues .
    I have put a lot of time and effort in making 316L top loops , Delran bushings and my own 316L top pins .
    You can see at the bottom right that the shafts are also cut in a mill to fit the round loops. And I have a fixture to hold them in place when I weld them together .
    If you ever get to the point where you want to fix yours , I have plenty of parts and I'll even take your cartridge in on trade ... even if I throw it in the dumpster
  4. Thanks Kcraft thanked for this post
    Likes baja200merk, vnemous, AZMIDLYF, Greg G liked this post
    Sep 2011
    Chaz,
    my top loop is rusted out on my 2008 300 xs. Do you rebuild the ram if I sent you my entire cylinder trim ? New ones are pricey!
    thanks
    mike kelley
    Mike ,
    Yes they are , yes I do ...
    I sent you a P.M.
    Baton Rouge, La
    What is the cost to shorten a stock 2.5 ram ? I'm putting together a Powell cut mid and figured it would be more desirable. Do you know the weight difference between the cut and factory short ram ? Thanks Mike
    Cheaters never Win !!!
    Mike , Here is my number .... 772-408-7377
    Call me , we can discuss condition , price , etc .
  9. Likes AZMIDLYF liked this post
    Baton Rouge, La
    Thanks Chaz , I will give you a call. Mike
    Sep 2002
    north port fl
    very nice!!!!!!
    Apr 2014
    nj
    Nice work ! Question , the original upper ram pin has a hole for a pin in order for the senders to operate. I have seen several pins snap there as I'm sure you've seen . I want to retain the senders however without a hole thru pin which weakens it . Was thinking of machining a flat spot and using a set screw . Thoughts?
    Quote Originally Posted by LOSTINJ View Post
    post #3
  14. #12
    Gravenhurst, Ontario.
    Chaz, what’s the best time to call you?
    Id like to talk to you about shortening a trim ram.
  15. #13
    Apr 2014
    nj
    My ram upper is mint , can and will your pin simply replace my stock flawed pin with the hole in center ?
  16. #14
    Quote Originally Posted by Tomanytoys View Post
    Tomanytoys ... ( greatproblemtohave )
    I responded to your P.M. sir , thank you ...........!
    ___________________________________________________________________
    lostinnj:
    Most pins I see are far from "mint" ( btw isn't that a coin collector term meaning uncirculated ? ) Anyway , if your's is in "good" condition , I think I would just tig weld the pin hole shut on both sides with 309 and mill a small flat on one side .
    If you just have to have a 316L solid pin ... I will be happy to build you one ..
  17. #15
    Sep 2002
    north port fl
    ttt
