Results 46 to 60 of 142
Thread: LOOPER TECH TIP's.........
03-23-2013, 09:13 PM #46Scream And Fly VIP
- May 2001
- Hickory NC
- 5,583
- 18
- 250
- 204
- 464
- 4 Post(s)
Several good points made by Gary, Lokintuz and Power. To fully understand the cooling issue it helps to have a block in several sections and being able to repeat tests is critical. The angle Gary is cutting leading into the chamber does help relieve detonation because the squish band is too wide for running over 6000rpm. I can tell you a deep narrow chamber is more detonation prone than a wider shallower chamber with the same CC volume, now take that wide shallow head and make the corner tight and it makes more power but you best be right on with timing and jetting. The factory adds a radius to the stock head in Garys second photo to give it some room adding the 45 raises the rpm band of the head. I am working on rechambering the closed deck head since the 2.7 is NLA, I am recutting the entire chamber. Have cut several up yet still looking for a good balance in power/safety while retaining head integrity (thats the tough part right now). I test the chamber design on removable chamber billet heads as it quicker and easier to do.
03-23-2013, 09:26 PM #47Scream And Fly VIP
- May 2001
- Hickory NC
- 5,583
- 18
- 250
- 204
- 464
- 4 Post(s)
Two issues that has been noted several times on this board is no ratchet in the lower unit and the carbs being lean in the middle. The non ratchet makes the carb issue worse. Adding pull over tubes helps and making sure your mid range jetting is very safe. I do have a way to make even a mod engine like Lokinutz 4 stroke problem is its very hard to explain and done wrong will ruin the carb, I did the mod to Darrens carbs and he actually had to lean down his mid jetting. Before you ask Darren was sworn to keep it quite, last he and I talked even after full disassembly he could not find one part and a critical part to making this work. This is a mod for big bores on mid bores they are way rich and ruins the carb. If you have a basic stock engine I would run a 106 pull over and as more mods are done go smaller, light clean up with 140 psi more like a .093 and so on. I hope this helps.
03-24-2013, 05:25 AM #48
Good stuff Al. Thanks for contributing.
I play with the pull overs on everything hot rod that I play with. Makes a huge difference in tuning.
I tap the pull over hole to accept screw in main jets. Perfect use for the old drilled out **** jets everyone tries to run in these things.I'd rather be competitive w/junk I built in my garage than win w/stuff I bought.
Checkmate 16' 140 Johnson
Laser 480 (?) 21' w/GT 200
24' Sonic w/twin 250 Johnsons
03-24-2013, 06:40 AM #49
nice thread but lets not forget about the top bearing caps bolt that back out and the occasional voltage regulator failure or poor connections to it in salt water apps that eats the head gasket and block surfaces.
24 Superboat
New Motors every week
03-24-2013, 09:21 AM #50Screaming And Flying!
- Jun 2007
- Singapore/Melbourne/Italy
- 9,109
- 1010
- 356
- 4327
- 1976
- 8 Post(s)
loctite?
03-24-2013, 11:05 AM #51
Interesting stuff, thanks for posting Al.
I have a set of big bores with a brass tube pressed into the carb and its tapped for idle/mid air bleeds.
Beef had an 88 225 on his mirage last month it had about 80-90psi compression with the stock 809s. We put my cut Mad EFI heads on it with thick gaskets and the compression reliefs open and it bumped it to 150psi . We also pulled the air box re-jetted and put pullovers in the stock carbs. When we returned it to stock and forgot to remove the pullovers it would not run at all. It just 4 stroked the whole time, we yanked them out put the air box back on and it cleaned right up ran perfect, was a huge difference.
I saw you put mainjets in the pullovers on that 3.0 you did. I like the idea because beefs motor vibrated 3 pullover tubes out, I found 1 in the reed cage the other 2 went through the motor oh well its still runningLast edited by baja200merk; 03-24-2013 at 11:10 AM.
03-30-2013, 12:03 PM #52
Now I know why the Sonic motor popped.
Went to change my mid range jets from the 27's I had it in (30's were stock) to 28's or 29's to perk up the mid range a bit when I found 30's in all 12 carbs
So I'm running more compression and porting w/stock mid range jets........................, good
My notes even show 27's in them???
After dwelling on it for a while, I now remember leaning out the mid range when I first ran those motors w/the Bravo 1's on them. Boat was a slug and I wrote it off to pig fat break in jets when in reality it was a combination of 3/4" more diameter than I'm used to, and an additional blade, but the worst part..................................., no exhaust reliefs in the props. Doh!
I figured that out about the time I swapped motors for the stock 250's that Paul now owns.
Then, forgot about re-jetting my motors. Can't believe they ran as long as they did. 2 steps fat on the mains is the only reason they did.
DOH!I'd rather be competitive w/junk I built in my garage than win w/stuff I bought.
03-30-2013, 12:48 PM #53
Man, I hate it when I do stuff like that.... Glad you found it.
Ló fasz racing
Joe Horvath
03-30-2013, 01:13 PM #54I'd rather be competitive w/junk I built in my garage than win w/stuff I bought.
11-17-2013, 01:53 PM #555000 RPM
- Sep 2011
- Deplorableville
- 740
- 1347
- 76
- 3211
- 1452
I hate to bring up an old thread, but I have an 89 225 that I want to update the cooling system. Will these mods shown work better that the 1992 70hp mods? I just want to make sure that I don't cook my motor.
11-17-2013, 05:26 PM #56Screaming And Flying!
- Jun 2007
- 9,109
- 1010
- 356
- 4327
- 1976
- 8 Post(s)
Instigator liked this post
01-24-2017, 01:35 PM #57
Bring this to the top for some of the people asking me for help.
01-24-2017, 04:51 PM #58
01-24-2017, 10:26 PM #59
08-22-2017, 08:24 PM #60I'd rather be competitive w/junk I built in my garage than win w/stuff I bought.
