Results 1 to 14 of 14
Thread: hydrostream vegas hard to steer
07-24-2011, 05:00 PM #1Junior Member
- Jul 2011
- georgia
i just purchased a 83 hydrostream vegas. with merc 200 black max, the boat runs good, but is hard to steer, the cables do not look old, torque pulls the wheel as well. i want to run the boat wide open, but steering gives me no confidence to do so. this is my first boat, is this normal? i've seen a v king w/ hydraulic steering guy says its much easier to drive. also the vegas doesnt seem to respond much to trimming up. other than shooting a giant rooster tail. any advice for a new performance boater would be nice...
07-24-2011, 06:59 PM #27000 RPM
- Mar 2009
- Port Saint Lucie
- 2,523
- 31
- 250
Does the skeg have a Torq tamer on it? If not it prob needs one.
07-24-2011, 07:08 PM #3
first thing that comes to mind is the engine is to deep i got the same problem but cant go up to much more or ill loose water pressure
and at certain speeds its not hard at all
lets see pics of your steering and the engine height
maybe some one can spot the problem
7 to 3pm 5 days a week
Custom Fiberglass and Paint
In Business since 1984
for sale
07-24-2011, 07:32 PM #4Screaming And Flying!
- 14,701
- 380
- 1280
- 5599
- 10934
x2 on the torque tab.... Makes a lot of difference. Very inexpensive and easy to install.
07-24-2011, 07:35 PM #5
Is it hard to steer with the boat at rest?
07-24-2011, 08:42 PM #6
for sale
07-24-2011, 08:55 PM #7
07-25-2011, 04:53 PM #8Junior Member
- Jul 2011
- georgia
first thing (i should have done already) going to clean off all crusty dried up grease on cables and rest of motor. then re-grease and lube everything. i will take some measurements (prop below hull) and check for a hook in the pad, i think torque tamer is installed, i will post pics of foot, the steering and the second prop and i got with the boat it is a Dennis 26 pitch
07-25-2011, 06:27 PM #9Junior Member
- Jul 2011
- georgia
posted some pics on my profile of motor and steering also the denis prop, sugestions? too low the motor can go up its in the top bolt hole.
07-25-2011, 06:39 PM #10
Steering cables look kinked. Still not clear if this is hard to steer sitting on the trailer.
07-25-2011, 06:46 PM #11
Is that transom cracked? no low water pick up. jack plate if transom is good along with low water pick up and jack the motor up. water pressue gauge is a must.. not a bad looking boat, be worth findding a hdy stearing and put in it
1990 hydrostream virage diamondpower280
07-26-2011, 06:31 PM #12
looks like the transom lead a hard life and needs some attention before you spend any time or money on the rest of the boat. Bimond plate is not the fix for a rotted and broken transom.
07-26-2011, 06:53 PM #13
Looks like it had a jack plate that was removed, now the cables are to long causing the kink. Need to find out how solid the hull is before doing to much.
07-26-2011, 07:27 PM #14Junior Member
- Jul 2011
- georgia
transom has been suposedly redone also floor has been replaced, i think the wood was replaced but the replacer must not have been familiar with gel coat...when i put weight on the transom it seems very solid, no flex at all, big plans to fix... need to unload drag car first....for sale 83 buick regal lader bar car 400 small block chevy power....
