Results 1 to 14 of 14
    Jul 2011
    georgia
    hydrostream vegas hard to steer
    i just purchased a 83 hydrostream vegas. with merc 200 black max, the boat runs good, but is hard to steer, the cables do not look old, torque pulls the wheel as well. i want to run the boat wide open, but steering gives me no confidence to do so. this is my first boat, is this normal? i've seen a v king w/ hydraulic steering guy says its much easier to drive. also the vegas doesnt seem to respond much to trimming up. other than shooting a giant rooster tail. any advice for a new performance boater would be nice...
    Mar 2009
    Port Saint Lucie
    Does the skeg have a Torq tamer on it? If not it prob needs one.
    Apr 2007
    first thing that comes to mind is the engine is to deep i got the same problem but cant go up to much more or ill loose water pressure
    and at certain speeds its not hard at all
    lets see pics of your steering and the engine height
    maybe some one can spot the problem
    7 to 3pm 5 days a week
    Custom Fiberglass and Paint
    In Business since 1984
    for sale
    x2 on the torque tab.... Makes a lot of difference. Very inexpensive and easy to install.
    Is it hard to steer with the boat at rest?
    Apr 2007
    mines not
    we dont even know what foot he has or nothing yet
    for sale
    Virginia Beach
    right where this thread should go. First gotta determine if the steering system is ok...which can be determined by steering it at rest, then disconnecting the cables from the engine and trying again.
    John
    Jul 2011
    georgia
    first thing (i should have done already) going to clean off all crusty dried up grease on cables and rest of motor. then re-grease and lube everything. i will take some measurements (prop below hull) and check for a hook in the pad, i think torque tamer is installed, i will post pics of foot, the steering and the second prop and i got with the boat it is a Dennis 26 pitch
    Jul 2011
    georgia
    posted some pics on my profile of motor and steering also the denis prop, sugestions? too low the motor can go up its in the top bolt hole.
    Steering cables look kinked. Still not clear if this is hard to steer sitting on the trailer.
    May 2009
    catskill ny
    Is that transom cracked? no low water pick up. jack plate if transom is good along with low water pick up and jack the motor up. water pressue gauge is a must.. not a bad looking boat, be worth findding a hdy stearing and put in it
    1990 hydrostream virage diamondpower280
  12. #12
    longisland
    looks like the transom lead a hard life and needs some attention before you spend any time or money on the rest of the boat. Bimond plate is not the fix for a rotted and broken transom.
  13. #13
    Looks like it had a jack plate that was removed, now the cables are to long causing the kink. Need to find out how solid the hull is before doing to much.
  14. #14
    Jul 2011
    georgia
    transom has been suposedly redone also floor has been replaced, i think the wood was replaced but the replacer must not have been familiar with gel coat...when i put weight on the transom it seems very solid, no flex at all, big plans to fix... need to unload drag car first....for sale 83 buick regal lader bar car 400 small block chevy power....
