Results 1 to 7 of 7
07-08-2011, 05:28 PM #1Junior Member
- Jul 2011
- labadieville,la
- 11
is it possible for a 460 jet boat to do 100mph on pump gas
I have a 460 pi in a 18ft baja hull . The pump is no good and I have to take down and rebuild the engine. I want to get as much hp on pump gas as possible. And be able to ride around on the weekends.
07-08-2011, 06:24 PM #2Banned
- Dec 2002
- 3,521
No way..
07-09-2011, 06:02 AM #3Scream And Fly VIP
- Sep 2002
- Alabama
- 705
Originally Posted by bigdaddy4280bama hama
07-09-2011, 07:28 AM #45000 RPM
- Jul 2006
- Walled Lake, MI
- 928
Anything is possible with enough $$$$$$$$$$$$$$$
07-10-2011, 02:11 PM #5Junior Member
- Oct 2010
- LAKELAND, FLORIDA
- 18
Eagle has a new stroker kit for around $1400 no clearnce required comes crank, h beam rods, and pistons. Bored 100 over comes out to 557 ci. With that and alum heads you can run 11:1 comp on pump gas and get close to a 100 mp.
07-11-2011, 08:56 AM #6
100 mph with a 460 jet boat, yes, it's possible, but not with the engine in "stock" configuration. Most stock 460 jets will run in the upper 60's to mid-70's, depending on hull design, weight, and set-up.
As for going 100 mph in an 18' Cobra, not sure I'd want to, except to make one GPS pass just to be able to say "See!"
GaryB> Darskide's Calling
'86 Eliminator Daytona/225 Excel in V-6 Special "Now hitting 90!!"
07-11-2011, 05:32 PM #7
I have a couple friends that have stroked 501 CI Ford's, one in a 18 BAJA , one in a Taylor LP both boats are running mid 70's with considerable pump work. Don't think the BAJA is capable of triple digits, both boats are on the edge as it is.
UMPBA 926 Gas Jet
