Results 31 to 45 of 57
  1. #31
    Oct 2010
    Harrisburg,Pa
    Quote Originally Posted by Riverratt View Post
    I am being serious. The purpouse of the hole in the tab is to pick up cool water and it runs it though a passage and releases it into the exhaust so it has cooler water discharging around the prop. I know a few things about OMC's. I don't just make this sh*t up
    Yea sorry Ralph you had me thinking a-- backwords there for a moment.DA There for a second I thought you thought it squirted water out that little hole!! Silly me
  2. #32
    Dec 2001
    Sunbury, Pa
    Quote Originally Posted by perfmarine1 View Post
    Stick with me and you will learn something I re read what I originally typed and I could see how you could be confused.
    Ralph Musser
    27' Fountain Fever W/ 525SC
    22' Rapid Craft W/ Evinrude 300 V8 January 2009 BOAT OF THE MONTH SOLD
    24' Triton 240 Gold W/ Mercury 60
    14' Royalcraft W/ Evinrude 75 father/daughter project
  3. #33
    Mar 2009
    Port Saint Lucie
    Well that makes sense. The exaust is open at the cavplate so there's not much exaust going around the prop. From looking at the inside of the lower I get how it works, and that is exactly how it is set up. You learn something everyday.
  4. #34
    Oct 2010
    Harrisburg,Pa
    Ralph, Boy I am glad we got that straightened out. In all serousness it may work better to leave the tab off with no cover plate ,when jacked up cuz the hole is bigger to except more spray off the prop wash,rather than that little hole taking in spray.
  5. #35
    Mar 2009
    Port Saint Lucie
    Well here it is..... I just sanded it down, gelcoated the top and sanded it smooth, rattle can primed and painted it. It came out good, not perfect but i dont really care as long as it works.
    Attached Thumbnails Attached Thumbnails IMG_1068.jpg   IMG_1069.jpg   IMG_1070.jpg   IMG_1071.jpg
  6. #36
    Mar 2009
    Port Saint Lucie
    last 2
  7. #37
    Gorilla you will like the foil, glad to see you got a real prop
    Ralph stop running fishing boat props
  8. #38
    Mar 2009
    Port Saint Lucie
    The prop is good, I need to send it out to be worked one day. It could use more pitch and cup. I hope it works, the boat was fine before, but going slow was a pain, so I'm hoping it will help and with launch a bit. I hope to test it by at least tomorrow.
  9. #39
    Dec 2001
    Sunbury, Pa
    It is a fishin boat motor so it needs a fishin boat prop.
    Ralph Musser
  10. #40
    The biggest improvement in holeshot we have ever seen on the action was adding 40 psi of compression to my brothers old wore out mullet boat 225
  11. #41
    Mar 2009
    Port Saint Lucie
    How did you add the compression? I know ou can plug the idle relief holes, and mill the heads, but then dont you have to rejet? I would like to raise the 90psi I got now...
  12. #42
    Well this old 75psi commercial mullet boat motor had umpteen thousand hours on it so since we had about $50 in the motor we put 2.7 heads on it then cut them a few times till compression was up 110-120 then plugged the reliefs We wanted to go to 150 but we were worried about squish
    Put yours around 130-140 it will wake it up in the mid range but you have to run 91 or better no more 87
  13. #43
    Oct 2010
    Harrisburg,Pa
    Hey,check out the hydrofoil on the Allison in the buy and sell section,boats to 20' its a xr2001 carbon fiber drag boat. Note how it looks bigger on one side then the other?
  14. #44
    Mar 2009
    Port Saint Lucie
    The stbd side is missing the wing that comes off it. Dont know why, but i'm sure its for something. But its still UGLY!
  15. #45
    Mar 2009
    Port Saint Lucie
    Well I think it works great, alot better than before. I can come onto plain slow and maintain it no prob. I can jack the motor all the way up, and tuck the motor a little and take off with out cavitation, comes up right away. I need to watch it while someone else drives to actually see how it runs. So far so good.
