Page 2 of 4 FirstFirst 1 2 3 4 LastLast
Results 16 to 30 of 57
    Mar 2009
    Port Saint Lucie
    [QUOTE=perfmarine1;2188874]Hey Gorilla you might as well take that steering touque tab off its not doing anything at that height.It don't look like a anode, Just extra weight!!!!![/QUOTE\
    I know it doesnt do anything at full height, but cruising around it makes a little difference, I can deffinatly tell when it comes out of the water. Also there is a small water pick up on it that does something, not sure what but something...
  2. #17
    Mar 2009
    Port Saint Lucie
    Well you got me thinking, take it off, or leave it on..... Opinions?????
  3. #18
    Bristol, WI
    Perfmarine1 is right, if your surfacing the prop at all, the tab is completely useless. Put a torque tab on the skeg and your good to go! I like the hydrofoil.
    Jr.
    Larry Gempp Jr.
  4. Likes KIRCHNER liked this post
  5. #19
    Mar 2009
    Port Saint Lucie
    There is a torq tab on the skeg already. I guess I'll fill in the hole in the foil and take it off. I like the way it looks with it off better anyways.
  6. #20
    Mar 2004
    Lexington SC
    has anyone ever had anyone tell them how these will work on a STV?
  7. #21
    Mar 2009
    Port Saint Lucie
    Well I took off the tab and filled in the hole that I cut for it. Looks better anyway, dont know when I'll get to test it, prob next week, I'm just going to paint it all black with the aluminum fins. Going to look for taller ones, there just wakeboard fins.
    Attached Thumbnails Attached Thumbnails IMG_1021.jpg   IMG_1022.jpg   IMG_1023.jpg   IMG_1024.jpg
  8. #22
    Jul 2007
    Hamilton Ohio
    Quote Originally Posted by specboatops View Post
    I think Gary (Liberator21) on here has made a bunch of his own stuff, give him a shout if he doesn't see this.
    Chris
    Thanks Chris, just ran across this post. I've had and made several. The "SKID PLATE" is normally attached to the J/Plate and in either a fixed position and or moveable position plate on a Hyd. J/Plate. I bought a cav mount plate a few years ago from a guy on "FASTBASS" for my 225x bass boat motor, it was an Ally knock off but worked very well and attached to the bottom of the cav plate similar to the one posted here. If one really needs help upon launch a cav plate mounted design would provide the most benefit at all speeds. The "SKID PLATE" is mostly for coming off plane and allowing the stern where the skid plate is mounted to let the hull settle back in the water without putting the stern to deep and getting wash over back there and also a benefit for keeping water from collecting in the J/Plate or Static Set Back upon launch thereby acting like your drag'n a parachute when your trying to get on plane.
    Gary
    Growing old is inevitable, growing up is optional.......
  9. #23
    Dec 2001
    Sunbury, Pa
    I would let the torque tab on. That little hole sprays water on the prop hub to keep it cool. I took mine off to put a plate on before going to the Romp a few years ago and it was the only time in my life I ever spun a rubber hub. It was melted bad. I put it back on and never had another problem.
    Ralph Musser
    27' Fountain Fever W/ 525SC
    22' Rapid Craft W/ Evinrude 300 V8 January 2009 BOAT OF THE MONTH SOLD
    24' Triton 240 Gold W/ Mercury 60
    14' Royalcraft W/ Evinrude 75 father/daughter project
  10. #24
    Mar 2009
    Port Saint Lucie
    Thats what I was told it did, I have switched to a solid hub (merc chopper 2)do you think there will be a prob? If you look inside the lower, I'm not sure how it sprays on the prop shaft. You can see the tube it goes into, but it doesnt seem to go to the prop shaft. I'll look when I get home. The hole was a bit off anyways, so if I need to I will redrill it. Besides when I'm running its not in the water, so does it still cool the hub???
  11. #25
    Oct 2010
    Harrisburg,Pa
    Quote Originally Posted by Riverratt View Post
    Yea thats a good one Ralph HA HA HA
  12. #26
    Oct 2010
    Harrisburg,Pa
    Quote Originally Posted by Gorilla0178 View Post
    Gorilla,I am sure that was a joke, there is no chance that little hole is going to spray water on the prop hub,its designed to take water in when run at stock height,jacked up it turns into a drain hole,you could take a garden hose and spray it at the prop and at 3000-6000 rpm it would not make it to the hub,the blades would make sure of that.
  13. #27
    Mar 2009
    Port Saint Lucie
    Well thats what the mechanic said and he said it to. I'll take pics of the inside of the lower when I get home. It deff has a tube that leads water somewhere in the lower, but it looks like it dumps into the exaust area.
  14. #28
    Dec 2001
    Sunbury, Pa
    I am being serious. The purpouse of the hole in the tab is to pick up cool water and it runs it though a passage and releases it into the exhaust so it has cooler water discharging around the prop. I know a few things about OMC's. I don't just make this sh*t up
    Ralph Musser
  15. #29
    Oct 2010
    Harrisburg,Pa
    Ok.I looked it does add water to exhaust,Ralph that had to be a fluke,I have been running with block off plates on all my motors,cuz big props will hit that thing,and have never spun a hub. No 2.5 race motor have them they are blocked off as well.Now maybe just maybe with a thru hub it would have a affect on cooling the hub,I doubt it,but flying through the air jacked up,or in a little spray, it can not.
  16. #30
    Dec 2001
    Sunbury, Pa
    Greg I was running a 4 blade through hub with a rubber hub and the propshaft about 2 inches below. Keep in mind my v8 is a fire breather and I have a much heavier boat.
    Ralph Musser
