Page 2 of 2 FirstFirst 1 2
Results 16 to 22 of 22
Thread: VST delete
    Texas
    Other than ProComp, is anyone running an OEM promax ECU with the fuel pump/regulator modification?
  2. #17
    Feb 2023
    fl
    My VST delete is not going well. All plumbing is done, 38psi fuel pressure regulated, fuel is dumping into motor.
    I think I have an o-ring issue on the fuel rail? Even without cranking the motor the pump would not build pressure over 25psi. I hooked the supply and return together to set pressure and tried again with same result. I have to crank the motor with no fuel supply and let it run all the fuel out. It won't even try to start with fuel pressure.
    Update: I took the fuel rail out and found a pinched o-ring on 1 injector. That was causing fuel to run out of rail and into reed valve then into motor.
  3. #18
    Jun 2009
    Bristol, Connecticut
    Does someone have a schematic and picture of how to do this on a 3.0 225
  4. Likes PurpleHaze94 liked this post
  5. #19
    Aug 2019
    H-Town
    Quote Originally Posted by Aaronhl View Post
    Anyone??? I'm considering performing this mod as well.
  6. #20
    Baton Rouge, La
    PPE delete kit
    Vst delete
    Cheaters never Win !!!
  7. #21
    Aug 2019
    H-Town
    Quote Originally Posted by tunnelmike View Post
    Vst delete
    Damn, that's a clean set up! Can I get all of those parts from PPE?
  8. #22
    Baton Rouge, La
    I also had to purchase the 2-90* fittings and the gauge. Oh and the push lock hose also. I know the gauge faces backwards but without a 90* that was how it needed to sit. I only used it to set the pressure. Mike
