Results 1 to 13 of 13
    Apr 2010
    South Lake Tahoe, NV
    21 Sleekcraft Mod V tunnel- set up help
    Well, I'm getting the transome rebuilt next week to start. All composite with aluminum plates inside and out. Got a hydrolic bob's jack plate, seastar pro hyd streering. Made the big purchase and bought an 05 300x that was rebuilt by simon motor sports. Gutted the upholtry and looking for good safe seats. Not sure what all I'm going to need for contols yet? Thinking about getting a hot foot and have the older merc controls still with the boat to shift it if I can get that to work? The boats is on the heavyer side with a solid floor that I was thinking about removing. Possibly going with something lighter and redoing the carpet while I was at it. I wanna see 90+ and Can't find anyone with this hull with an outboard. Originally had a 3.0 225 and it did 70. which would be blaa. Also would it be worth modifying the back of the hull. The center pod has a slight V and was thinking about shaving the last foot of it flat for a pad to run on? Thanks for any advise , Mike
    JUPITER, FLORIDA
    Quote Originally Posted by D-Bay Runner View Post
    I pretty sure Capt Steve on this site had a Sleek Tunnel V..
    J-Town Hot Boat Team
    Barracuda 188CCR/Suzuki 140
    Past Boats:
    Checkmate 2800SX/Twin Merc 250’s
    Checkmate Pulsare 2400/Verado 300
    Checkmate Starflite/Merc Pro XB250
    Canadian Edition Hydrostream AE-21/Merc 2.5
    Checkmate Pulsare 2100/Merc 225Xri
    Hydrostream Valero YT Bowrider/Merc 175
    Talon T-21/Mercury Racing 2.5 Carb
    Sleekcraft ModVP Bowrider/Evinrude 225 Vindicator
    Velocity 230/Mercury 454 Magnum
    Scout 172 Sportfish/Yamaha 130
    SeaRay F16 Jet boat/Mercury SportJet
    SeaRay 17' Seville/Merc I/O
    May 2011
    Carpenter, Wy
    Is it a sst. How much setback?
    I'm getting ready to rerig mine it hasn't been on the water for seven years. I'm thinking on running 12inches with a 1997 260 offshore mid that I read has two more inches of set back than the standard ones that would put me at 14 witch seemed good back then
    May 2011
    Carpenter, Wy
    Oh ya what prop are you planning on running.
    Apr 2010
    Jack plated has 6'' set back. No prop yet, was thinking 26 to 28?? something with some lift and a surface prop. Any suggestions?? Might have to try a few out before I make the buy. Been looking at the twin tanks and old fuel lines. What do I need to make the fuel system work right. Not sure if I should just plumb each tank into a single fuel/ water seperator then into the X? Who's got solid seats for this thing? Would like something on the safe side to stay bolted down at high speed. Not an sst, its a JRT
    May 2011
    Carpenter, Wy
    I'm sorry it took a few. I'm not sure what the three liters weigh compared to the 2.5's if weight isn't my different than I would say you might want to run more than six inches of setback. Get her to fly with very little trim that weigh, faster that way. I ran a merc chopper but I'm sure there are better props now days I was gonna look into a the lightning et, and the yamaha drag. Any input guys?
    Jan 2011
    Bethel Island California
    D Bay Runner
    Send me a PM with your phone number....I live just down the road from you on Sandmound Slough. Can help with your boat set up as I have had
    several MOD Vs.
    Here's my Sleek...........
ID:	235866Click image for larger version.
ID:	235864Click image for larger version.
ID:	235865Click image for larger version.
    May 2011
    Carpenter, Wy
    Wow nice boat K Boat. what kinda engine bracket is that? And where can you buy one? How much set back? And If you dont mind do you think could post some speed and rpms, and what prop seems to work best. Any help would be greatly appreciated.
    That Sleek is sweet
    Nov 2009
    New Port Richey Florida
    Heres a few of my 1976 Aristocrat thats been slightly modified. 300 promax,10" sedtback, 28 pro ET, 12"x 18" Lenco trim tabs. These hulls like a lot of setback and the weight of the 3 litre. with the right setup you should see 90 with the 300X
    Attached Thumbnails Attached Thumbnails 006.jpg   013.jpg   007.jpg   5-22-10 042.jpg   PA082126.jpg
    Jun 2008
    kingman az
    Quote Originally Posted by K Boat Man View Post
    D Bay Runner
    several MOD Vs.
    ive seen this sleeker on another site...you or who ever did the resto job did an awesome job!
    Apr 2010
    Update: Found good seats online for it. Picked up a Rex foot control. Wanted any thoughts on the Bob's extreme Jack plate. This boat is on the heavy side and everyone is talking about big set back. How will this thing steer with that much set back? Seen the Bob's 10 inch set back Hydrolic jack plate. Motor is pushing 335 hp+. Also looking into props. I have a fat shaft on my 300x. Thinking to start with a 28. Not sure what cut?? thanks Mike
  12. #12
    Jan 2011
    Thanks!
  13. #13
    Mar 2023
    Hudson Florida
    Quote Originally Posted by FlatSleek View Post
    Whatever happened to this boat?
